Saving a JPEG file in photoshop CS3
Postby W00DY on Fri Jan 04, 2008 5:37 pm
Hi All,
Is there any other way to save a JPEG file other than "save for web"?
I have a TIFF image which I need to save as a JPEG but every time I use "save for web" I get an error message about memory (even though I have 4gig of the stuff!!!).
Anyone?
Andrew
W00DY
Postby W00DY on Fri Jan 04, 2008 5:40 pm
The Adobe resource centre says to just use "save as", but I don't have the JPG option in the format drop down under the "save as" option.
Andrew
W00DY
Postby Oneputt on Fri Jan 04, 2008 5:41 pm
Just use save as or even save and change the file type to JPEG - easy :D
Oneputt
Postby W00DY on Fri Jan 04, 2008 5:44 pm
Oneputt wrote:Just use save as or even save and change the file type to JPEG - easy :D
See my post before yours (we posted at the same time)... when I choose "save as" there is no JPEG option.
If I choose Save and change the extension will it be saved at the maximum quality?
Andrew
W00DY
Postby Oneputt on Fri Jan 04, 2008 5:55 pm
Woody it should still bring up the JPEG options box and you can select what you save it as. I cannot understand why you do not have the option under save as.
Oneputt
Postby Bob G on Fri Jan 04, 2008 5:58 pm
Woody - You may need to scroll up or down to find the option
Bob
Bob G
Postby Matt. K on Fri Jan 04, 2008 6:08 pm
Woody
Go to IMAGE/MODE and make sure it is 8 bit. Then when you go to SAVE AS jpg option should be available. :D
Postby W00DY on Fri Jan 04, 2008 6:15 pm
Matt. K wrote:Woody
That was it Matt, thanks.
I thought I was going crazy because I could not see it.. but the file was 16bit TIFF.
:D
Andrew
W00DY
Postby Handlebars on Fri Jan 04, 2008 6:27 pm
I'be been battling with the same issue...Thanks! Solved for me too :up:
C&C more than welcome!
Canon 300d...(hopefully not for too long though)
http://www.redbubble.com/people/HandleBars
Handlebars
Postby W00DY on Fri Jan 04, 2008 7:22 pm
And this is why I can't wait for the photoshop meet in February!!!
Andrew
W00DY
Postby Killakoala on Fri Jan 04, 2008 8:02 pm
It's a common and easy to make mistake, of which I was once a victim of, long ago.
Photoshop is complicated.
Postby Greg B on Fri Jan 04, 2008 9:26 pm
There are a few situations which can result in some file types being unavailable - another one
you may encounter is when you have a text layer, you will need to "Flatten Image" in the layer
menu before you can save as a Jpeg.
Greg - - - - D200 etc
- Arthur Schopenhauer
Greg B
Postby sirhc55 on Fri Jan 04, 2008 9:47 pm
Greg B wrote:There are a few situations which can result in some file types being unavailable - another one
 PS3 will enable you to save a file as a jpg with text layers. The image is automatically flattened :wink:
Postby Greg B on Fri Jan 04, 2008 10:01 pm
That's right, it just forces you to save as a copy, must be some other situation where jpeg isn't available,
(apart from the subject of this thread), can't quite remember what it is.
Greg B
Postby sirhc55 on Fri Jan 04, 2008 11:48 pm
Greg B wrote:That's right, it just forces you to save as a copy, must be some other situation where jpeg isn't available,
16 bit et al :wink:
Postby Handlebars on Fri Jan 04, 2008 11:48 pm
Does saving as a jpg this way keep the exif data?
Handlebars
Re: Saving a JPEG file in photoshop CS3
Postby wazonthehill2 on Thu Feb 07, 2008 7:07 am
Thank goodness for this site and threads.
I would have found that (8 bit vs 16 bit) was the problem myself, one day, maybe, in 2040!
Thanks guys
whizzzz, there goes life again.....
But now captured on a Canon 40D with bits
http://www.flickr.com/photos/wazonthehill/
wazonthehill2
Re:
Postby michael_ on Thu Feb 07, 2008 10:45 am
Handlebars wrote:Does saving as a jpg this way keep the exif data?
save-as does
save for web doesnt
also image process you can save as jpeg and set a heap of parrameters for the action and even attach an action to it, change colour space to sRGB, change the compression size although they scale 1-100 vs save-as which is 1-12, add a copyright, add a watermark, save in a different location, save multiple files if you are working on a heap of files on the worspace rather than doign them all individually.
michael_
Re:
Postby Nigell on Fri Feb 08, 2008 4:55 pm
Matt. K wrote:Woody
I have been battling with this for ages. Such a simple thing that no one seems to know about. Previously I was copying the image and pasting it as a new 8bit image. This worked but it did strip out the EXIF data. The Mode way does not. Thanks for the info.
Nigell
Postby Matt. K on Fri Feb 08, 2008 7:41 pm
Greg B
I'm trying to flatten the layers....do I push down on the monitor? The key board, or the mouse? It's just not working for me!!! How hard should I push??? :( :( :( :( :( :lol: :lol: :lol: :lol:
Return to Post Processing
