TC201
TC201
Postby biggerry on Sat Jan 09, 2010 7:20 pm
I got this Teleconverter cheap, not something I would actively go out and buy, however i think I may have a use for it.
Quality wise, I am on the fence at the moment, I guess you really need good glass to get the best benefits of this kind os converter. Anyone else got one of these?
First day with a bit of sunshine and the opportunity for something in the distance! taken with the 100-300mm at f5.6 iso 200 1/1500s
Re: TC201
Postby surenj on Sat Jan 09, 2010 8:36 pm
Gerry, the background and the lighting makes to plane look like it's been cut and pasted. I doubt this is anything to do with the lens or converter.
Do you have any other shots from this? Is this at 600mm effective length?
Re: TC201
Postby Murray Foote on Sat Jan 09, 2010 8:42 pm
I have a TC200, essentially the same thing, which I have probably had for 25 years. None of the reviews are very complimentary and I haven't used it since I got my D3. My longest lens is a 300mm f4 and I sometimes use that with a TC14E, which works well enough. I would have thought it would take a prime or a high range zoom for it to be reasonably viable but then teleconverters can behave differently with different lenses. I guess the practical test would be to compare an image using it to a crop without it.
Murray Foote
Re: TC201
Postby biggerry on Sun Jan 31, 2010 11:07 pm
heres one from tonight.. its a hit and miss with this I find... I used a tripod and another stand for teh lens..
300 * 1.5 * 2 = 900mm ??
Re: TC201
Postby surenj on Sun Jan 31, 2010 11:40 pm
Nice one Gerry,
I have a funny feeling you are not getting quite 900mm ??? Shouldn't the moon be bigger??? Oh wait, I think I used a 1200mm telescope back then to view the moon bigger. Perhaps this is the right size? :shock:
Re: TC201
Postby Murray Foote on Mon Feb 01, 2010 12:04 am
It looks sharp as a web image. I guess the tripod and the stand was the key to minimise vibration.
Murray Foote
Re: TC201
Postby aim54x on Mon Feb 01, 2010 12:25 am
That moon looks great Gerry...how long was the exposure? It wouldnt have been too long though!
Re: TC201
Postby Mr Darcy on Mon Feb 01, 2010 6:01 am
I'd like to see the moon cropped to fill the frame. Otherwise, great.
Oh and Cameron, EXIF says 1/125s
Re: TC201
Postby biggerry on Mon Feb 01, 2010 10:34 pm
yeah, i have done this in a qualitative terms and it does come across quite soft on the 100-300mm...i will try and do a proper comparison one day..
hows this?
Re: TC201
Postby biggerry on Mon Feb 01, 2010 10:57 pm
for completeness, here is the original file, no sharp, resized and jpeged and a 100% crop.
Return to First Image
Users browsing this forum: No registered users and 24 guests
