Random shots after the rain...
Postby XPLOSV on Thu Apr 23, 2009 4:41 pm
Hi All, I'm new on this forum.
Got into photographs for a short while and just thought I share some pics I took after raining day.
Sorry if the pictures a bit too big.
All straight off RAW, no edit.
Any comment is welcome.
Greatness is difficult to appreciate from close up. The great mountain on the horizon is only the ground when you are standing on it.
XPLOSV
Re: Random shots after the rain...
Postby Mr Darcy on Thu Apr 23, 2009 6:13 pm
I think you could lose #4 from the set. It is badly OOF. YOu have the leaves, not the flower & to my mind it just does not work. This would bring you down to the 4 photo limit in the rules.
Also, as you seem to have guessed, these are over the size limits. (800Px on longest side AND <= 200Kb file size) This is imposed to cater for the unfortunates who have a small monitor and/or slow connection.
You also need to put a meaningful location in your profile. This is mainly for your benefit. you would be surprised what you might get loaned by someone near you.
Having got that over with.
I quite like the other 4. Excellent use of DOF to separate subject from ground.
Postby zafra52 on Thu Apr 23, 2009 8:51 pm
I agree with Mr Darcy. Number 4 does not make justice to the rest. However, I like number 1 best or perhaps the last one? No, Number 1.
Postby XPLOSV on Fri Apr 24, 2009 9:47 am
thanks for the feedback guy.
Sorry I broke the rule.
Will edit/post accordingly.
XPLOSV
Return to First Image
