| Tutorials, questions, demos, questionable images ,,,
			Forum rulesPlease ensure that you have a meaningful location included in your profile. Please refer to the FAQ for details of what "meaningful" is.
			 by hrpremier on Wed Nov 26, 2008 10:06 pm
 This image was captured last Sunday Night, 22nd November 2008 as an electrical storm passed over Cairns.  This gave me an opportunity to play with some settings on my camera and try and get a good shot of the storm
 The picture I wish to highlight shows a large bright white area in the centre of the frame (The lightning itself).  What I wish to do is remove all the flash of the lightning and leave the bolt above my roof top.
 How if at all possible can I achieve this in Photoshop. The other hurdle I may have to overcome is that the photo was shot in jpeg format as my version of CS2 fails to recognise my 40d raw files.  Is there an update for CS2 available to fix this problem which someone can supply or point me into the right direction it would be appreciated.
 If anyone wishes to have a play with the picture you have my blessing.
 Thanks in advance
 hrpremier
 4869
  Guess What! ........I Have A Fever........And The Only Perscription........Is More Cowbell.
				 hrpremier
Member Posts: 156Joined: Mon Feb 04, 2008 10:18 pmLocation: Cairns, Queensland
			 by shazzm on Thu Nov 27, 2008 11:23 pm
 Wow, if u can work it out, I'd love to see the "bolt".
 I also have the same problem with CS2 - I can't import my Nikon D60 RAW files into Photoshop as the file is not recognised.
 Any help would be appreciated. Thanks
				shazzm
			Newbie Posts: 13Joined: Fri Nov 21, 2008 12:09 amLocation: Davoren Park, South Australia
			 by Gordon on Fri Nov 28, 2008 3:33 am
 Hrpremier, unfortunately there is a large region of saturated pixels around the lightning in the image, so there is no chance to recover the bolt in the middle of it all. The information is lost. Do you still have the original raw file on the memory card? It is possible there will be a lot more information in it.Anyway, Cairns isn't really short of lightning bolts, so next time try it with the aperture stopped down a bit more and or lower ISO setting.
 D70, D200, CP5700
				 Gordon
Member Posts: 436Joined: Fri Feb 18, 2005 11:04 pmLocation: Loomberah/Siding Spring Observatory
			 by gstark on Fri Nov 28, 2008 8:40 am
 hrpremier wrote:The picture I wish to highlight shows a large bright white area in the centre of the frame (The lightning itself).  What I wish to do is remove all the flash of the lightning and leave the bolt above my roof top.
 The problem here is that you've captured - and totally blown out - a very intense light source that exists within your image. I'm not sure that this is possible. Not to the extent that you would like. The other hurdle I may have to overcome is that the photo was shot in jpeg format as my version of CS2 fails to recognise my 40d raw files.  Is there an update for CS2 available to fix this problem which someone can supply or point me into the right direction it would be appreciated.
 There should be. We have many members here using that combination. Have you tried Google?g.Gary Stark
Site Admin Posts: 22926Joined: Thu Aug 05, 2004 11:41 pmLocation: Bondi, NSW
			 by Jonesy on Fri Nov 28, 2008 8:42 am
 Hey mate, you may be able to recover a little out of it by a levels or curves adjustment, but being a jpg you've lost the detail that would have still been in the raw shot to start with. On your other problem CS2 won't read 40d raws. the RAW update that contains the 40d info is for CS3 and up. Probably something with wanting people to stay up to date with the latest adobe products but I know that it doesn't help you or anyone else in the same situation... What you can do is download the adobe DNG converter> it will be an extra step but converting your RAWs to DNG will allow you to use and process them in CS2http://www.adobe.com/products/dng/  to read more and FREE download. Having said that it looks like the strike was fairly close! hows your pantsD4, D700, plus glass from 14mm to 200mmGaffa Tape is like the FORCE... it has a Light side, a Dark side and it holds the universe together
				 Jonesy
Member Posts: 498Joined: Thu Aug 25, 2005 5:41 pmLocation: Mount Gambier SA
			 by ozimax on Fri Nov 28, 2008 1:35 pm
 Can you not process the raw file in Canon Photo Professional, save as a TIF or whatever, then transfer to CS2? Otherwise as Jonesy has stated, download the DNG converter etc.
 Oh I see the point now, you want to use the raw file in CS2, yep, the DNG converter is the way to go. I use CS1 and do it this way.
 Ozi
 President, A.A.A.A.A (Australian Association Against Acronym Abuse)Canon EOS R6, RF 24-105 F4, RF 70-200 F4, RF 35mm F1.8, RF 16mm F2.8
Senior Member Posts: 5289Joined: Wed Jan 05, 2005 11:58 amLocation: Coffs Harbour, NSW
			 by hrpremier on Tue Dec 02, 2008 11:24 am
 Thankyou to all who replied.
 I have managed to get an image replecating what I was hoping to achieve in the first place.  I did this via photoshop and stiched a couple of images of other lightning shots i have captured over time and placed them over the top of my home, cut out of the original shot.
 I know its not he way a photographer hopes to capture an image but it is a result I was looking for none the less.
 Next time a storm passes over I will try to use advise from the post and get the shot the way I intended to the first time and shoot in RAW format.
 Thankyou again to all who posted comments and feedback.  Your assistance is appreciated.
 Heres a copy of the end result.
  Jase 4869 Guess What! ........I Have A Fever........And The Only Perscription........Is More Cowbell.
				 hrpremier
 Return to Post Processing |
