Straighten horizon ...
Postby blacknstormy on Sat Jul 12, 2008 8:13 pm
Benny - I've used your shot to illustrate what I meant, but if you like, I'll replace it with something else ...
Using crop tool select a small section ...
Put the cursor near the corner of the selection and it will turn into a circular arrow which allows you to rotate the section - I move the section and rotate it to match the horizon
The drag each of the corners of the selection out to the edges of the canvas - you will loose edges (how much depends on how much of a slant your horizon is on)
When you are happy, click on the tick to accept the crop changes
and then you have a straight horizon - just the way I do it
Re: Straighten horizon ...
Postby sirhc55 on Sat Jul 12, 2008 9:29 pm
The ruler tool is simpler and more accurate Rel :wink: :up:
Postby blacknstormy on Sat Jul 12, 2008 10:13 pm
sirhc55 wrote:The ruler tool is simpler and more accurate Rel :wink: :up:
:) Fair enough - but I don't know how to use it :) :)
Postby phillipb on Sat Jul 12, 2008 11:01 pm
1. Select the ruler tool
2. Drag the +pointer across the horizon line
3. Go to IMAGE-> ROTATE CANVAS -> ARBITRARY
4. Press OK
Done.
__________
Phillip
**Nikon D7000**
phillipb
Postby jdear on Sun Jul 13, 2008 11:52 am
even simplier, if you use bridge's camera RAW, is the ruler tool in that :D
draw line - crops.
pi$$ easy,
jdear
Postby Benny2707 on Tue Jul 15, 2008 7:46 pm
No problems at all.
Love the tuition!
D300 - MB-D10 - Nikkor 80-200mm f/2.8 - Tamron 17-50mm f/2.8 - Nikkor 50mm f/1.8 - SB600
My stuff here http://www.flickr.com/photos/22767657@N07/
Benny2707
Postby Bob G on Tue Jul 15, 2008 11:57 pm
Without trying to steal anybody's thunder, I'd suggest another tip when one doesn't what to loose much of the image by cropping.
Use the ruler as descibed above.
Select the whole image and use one of the tranform tools - dragging the appropriate corner til the horizon lines up with the ruler. This way you only lose from one corner rather than the whole image.
Of course it' a bit of "horses for courses" which way you choose
Bob
Bob G
Postby Jase555 on Thu Jul 17, 2008 8:27 pm
I used the ruler tool in Lightroom for my #1 Newcastle shot in the Images section, very easy to use... just drag across the horizon and it will make that line perfectly horizontal and level...
Proud Pentax user!
Images of life, land & speed
http://www.555images.com
Jase555
Postby gstark on Thu Jul 17, 2008 9:08 pm
Dare I suggest an even easier method?
How about looking through the viewfinder when making the image, and getting it right in the camera?
Postby phillipb on Thu Jul 17, 2008 9:14 pm
gstark wrote:Dare I suggest an even easier method?
What did you say?Speak up I can't hear you. :D
Jase555 wrote:I used the ruler tool in Lightroom for my #1 Newcastle shot in the Images section, very easy to use... just drag across the horizon and it will make that line perfectly horizontal and level...
Whereabouts do you find the ruler tool in lightroom?
__________
Phillip
**Nikon D7000**
phillipb
Postby Jase555 on Thu Jul 17, 2008 11:46 pm
In the crop view in the develop section. It's the straighten tool (think it may be a spirit level rather than a ruler... :oops: )
Proud Pentax user!
Jase555
Return to Post Processing
