| Tutorials, questions, demos, questionable images ,,,
			Forum rulesPlease ensure that you have a meaningful location included in your profile. Please refer to the FAQ for details of what "meaningful" is.
			 by big pix on Mon Oct 30, 2006 9:41 pm
 The Measuring Tool in Photoshop is not just for measuring distances but to also straighten the horizion.
 1. Using the Measuring Tool run a line along the existing horizon (or pole or whatever you would like to be perfectly horizontal or vertical) in your picture.
 2. Menu choose Image > Rotate Canvas > Arbitrary
 the degree of adjustment and direction need are automatically entered
 3. Click OK
 examples:
 .......before
   .......after...... then re-crop......
 Cheers ....bp.... Difference between a good street photographer and a great street photographer.... Removing objects that do not belong... happy for the comments, but  .....Please DO NOT edit my image.....        http://bigpix.smugmug.com   Forever changing
				 big pix
Senior Member Posts: 4513Joined: Thu Feb 17, 2005 11:52 pmLocation: Lake Macquarie NSW.
 by owen on Mon Oct 30, 2006 10:20 pm
 Very cool Bernie... something I did not know but will surely put to good use.
Senior Member Posts: 1699Joined: Thu Jan 06, 2005 3:21 pmLocation: Nowra, NSW
 by xorl on Mon Oct 30, 2006 11:13 pm
 I use the gridlines in GIMP 's rotation tool to fix orientation issues. I figure photoshop probably has something similar. This operation is very fast and is fairly accurate. The measure tool might be slightly better if you need perfection.Mark
				 xorl
Member Posts: 391Joined: Mon Feb 07, 2005 11:07 amLocation: Sydney, NSW
 by Steffen on Tue Oct 31, 2006 12:41 am
 The first one looks perfectly level to me...      I find the idea of presenting a heavily straightened image without cropping very interesting. It just adds a lot more interest and dynamics.
 Steffen.lust for comfort suffocates the soul
				 Steffen
Senior Member Posts: 1931Joined: Mon Oct 31, 2005 4:52 pmLocation: Toongabbie, NSW
 by CraigVTR on Tue Oct 31, 2006 2:18 pm
 Thanks Bernie  Iam going to use that heaps.      CraigCraigLifes journey is not to arrive at our grave in a well preserved body but, rather to skid in sideways, totally worn out, shouting, "Wow what a ride."
 D70s, D300, 70-300ED, 18-70 Kit Lens, Nikkor 105 Micro. Manfrotto 190Prob Ball head.  SB800 x 2.
				 CraigVTR
Senior Member Posts: 1243Joined: Fri Feb 03, 2006 6:09 pmLocation: Montville, Sunshine Coast, Queensland
 by Viz on Tue Oct 31, 2006 6:57 pm
 Once again the noob can't restrain his oversized yap    - so no offense to Big Pix because this is probably one of the most criminally unknown functions of photoshop...
 If you are using a RAW workflow there is a tool for this in ACR (Adobe camera raw) called the 'straighten tool' which avoids re-interpreting the pixels once you straighten the image, instead it will create straightened pixels from the (presumably) bayer pattern of the sensor. In short minimising data-loss however small and anally retentive.
 But for ALL situations other than RAW - Big Pix's method is the absolute bomb.
				 Viz
Member Posts: 176Joined: Fri Oct 13, 2006 8:46 pmLocation: Leichhardt, Sydney
 by drifter on Tue Oct 31, 2006 10:06 pm
 Great tip . Thankyou. I have always done this previously by trying three or four different numbers incrementally in the arbitrary box . Tony
				 drifter
Member Posts: 372Joined: Thu Oct 06, 2005 8:37 pmLocation: Croydon -Sydney
			 by zafra52 on Wed Nov 01, 2006 8:16 pm
 Thanks Bearnie, you taught me something new today! And it is very handy to know it too.
Senior Member Posts: 4877Joined: Thu Dec 01, 2005 10:22 pmLocation: Brisbane
			 by DVEous on Wed Nov 01, 2006 8:46 pm
 ... Obsolete ... Last edited by DVEous  on Sun May 04, 2014 7:18 pm, edited 1 time in total.
				 DVEous
Senior Member Posts: 687Joined: Sat Jul 02, 2005 1:32 pm
 by beetleboy on Wed Nov 01, 2006 9:56 pm
 Yup..very handy that one Big Pix (Shortcut key = I [cycle thru the tools with Shift-I]).
 Another method is to use the crop tool (Shortcut key = C) and make a small selection across your horizon; then rotate the crop (move your cursor outside the crop area and it will change to a "rotatey" tool!) to match your horizon. Now just move your crop bounds out to the edges and hit Enter! Voila! Sounds long winded but it's quick, trust me!
 You can also use this method within ACR to the same effect.
 I use both of these methods depending on the circumstances.
				 beetleboy
Senior Member Posts: 821Joined: Fri Sep 17, 2004 4:57 amLocation: Highbury, Adelaide
 by blacknstormy on Wed Nov 01, 2006 10:08 pm
 Thanks for the tip Bernie    I must admit I just use the crop tool, as explained by Liam   , but will have a go at the measuring tool now   BTW  - I've found that drinking and taking photos results in the horizon seen in the first shot   LOL
Senior Member Posts: 2745Joined: Wed Dec 29, 2004 3:33 pmLocation: Ipswich Qld
 by Manta on Wed Nov 01, 2006 10:15 pm
 I've been using the measure tool for ages but had forgotten someone (can't remember who) had mentioned the ACR technique before. Must look into that.
 Thanks Bernie and others.
Former Outstanding Member Of The Year Posts: 3815Joined: Tue Nov 30, 2004 10:49 pmLocation: Hamilton Qld
 Return to Post Processing |
