| Tutorials, questions, demos, questionable images ,,,
			Forum rulesPlease ensure that you have a meaningful location included in your profile. Please refer to the FAQ for details of what "meaningful" is.
			 by gleff on Fri Oct 06, 2006 9:40 pm
 Hi All,
 I have the following image of Lisa McCune that I want to extract from the background and i'm having trouble doing so because of my crappy photoshop CS2 skills.   The problem i'm having is with the area around the neck and left side where it blends in with the guys suit, and also the hair.
 Can anyone give me some suggestions on the best way (preferably step by step) or via a tutorial on how to extract her from the image so I can plant her on a new background.
 Any help would be appreciated.
 Here is the image to demonstrate.  The one i'm working on doesn't include the frame or watermark though.
 Thanks
 http://www.gleff.com
_________________
 D70, 18-70 kit , 80-400VR, 24-120VR, Sigma 10-20, SB800, Benro A328, KB-2 Ballhead
				 gleff
Senior Member Posts: 502Joined: Mon Jan 24, 2005 1:49 pmLocation: Chatswood, NSW - Nikon D70
 by phillipb on Fri Oct 06, 2006 10:08 pm
 Hi geoff,
Just a thought, if you're just trying to get rid of the guy next to her, it may be easier to clone out the jacket.
 __________Phillip
 **Nikon D7000**
				 phillipb
Senior Member Posts: 2599Joined: Sat Aug 07, 2004 10:56 amLocation: Milperra (Sydney)       **Nikon D7000**
 by gleff on Fri Oct 06, 2006 10:11 pm
 phillipb wrote:Hi geoff,Just a thought, if you're just trying to get rid of the guy next to her, it may be easier to clone out the jacket.
 I'm trying to get rid of the guy and extract Lisa from the entire background.  I'm just having trouble because of the darkness around the next/suit area and with the hair.  I think I need to do something with channels and levels but i'm having a hell of a time doing it.. nothing is working.http://www.gleff.com
_________________
				 gleff
 by shakey on Fri Oct 06, 2006 10:13 pm
 Well I'm no PS  expert but....
 use the extract filter (in filter menu) rather than the selection tools.
 history brush to paint back in any missing bits
 Detailed explanation in Scott Kelby's book "Photoshop CS2 book for digital photographers" p260-265 (if you happen to be walking past a bookshop..) ..if you keep on reading it will also tell how to do digital botox for those eye wrinkles...
				 shakey
Senior Member Posts: 696Joined: Sat Apr 09, 2005 9:24 pmLocation: Far South Coast NSW
 by big pix on Fri Oct 06, 2006 10:33 pm
 http://www.russellbrown.com/tips_tech.html
.......will give you the answer........ called background extraction Cheers ....bp.... Difference between a good street photographer and a great street photographer.... Removing objects that do not belong... happy for the comments, but  .....Please DO NOT edit my image.....        http://bigpix.smugmug.com   Forever changing
				 big pix
Senior Member Posts: 4513Joined: Thu Feb 17, 2005 11:52 pmLocation: Lake Macquarie NSW.
 by joolz on Fri Oct 06, 2006 10:41 pm
 I agree with Shakey that the extract tool is quite handy and does a decent job.
I have a Katrin Eismann book "masking and compositing" which goes through a few good (but advanced) techniques that I would recommend if you want to learn some complex but effective ones.
 Julian
				 joolz
Member Posts: 241Joined: Sun Sep 12, 2004 12:45 amLocation: Preston, Melbourne
 by wendellt on Sat Oct 07, 2006 2:03 am
 you can use the lasso tool in photoshop to select the jacket and fill the space with black, then you will isolate lisa
 anyway as a side not next tiem you do red carpet
 ask lisa to step away from her partner the partners know its not rude to ask if you take a shot without them
 celebs like lisa are used to being asked to get a solo full length without her partner
Outstanding Member of the year (Don't try this at home.) Posts: 4078Joined: Sun Feb 20, 2005 10:04 amLocation: Dilettante Outside the City Walls, Sydney
 by gleff on Sat Oct 07, 2006 8:46 am
 Thanks everyone for your help.  I've been playing around and it's pretty clear i'm going to need some major practice with this.
_________________
				 gleff
 by gleff on Sun Oct 08, 2006 2:58 pm
 This is the end result of playing..  There are some areas that I can't seem to fix so it's not perfect but as a small photo to someone perhaps not looking for problems it may look okay.. what do you think..
_________________
				 gleff
 by sirhc55 on Sun Oct 08, 2006 3:27 pm
 Not bad Geoff except I would clone the slight hot spot on the right cheak  Chris--------------------------------
Key Member Posts: 12930Joined: Fri Sep 17, 2004 6:57 pmLocation: Port Macquarie - Olympus EM-10
 by gleff on Sun Oct 08, 2006 3:31 pm
 sirhc55 wrote:Not bad Geoff except I would clone the slight hot spot on the right cheak
 Is that any better?http://www.gleff.com
_________________
				 gleff
 by Oz_Beachside on Sun Oct 08, 2006 4:24 pm
 nice job.  I learned this technique from the "Dr. Brown" tute posted above.
 Perhaps you could forgo some of the hair on picture left, below earing height, as your extraction has taken too much out.
 But a great extraction non-the-less
 Oz
				 Oz_Beachside
Senior Member Posts: 2227Joined: Thu May 25, 2006 11:31 pmLocation: Black Rock, Victoria.  D200
 by shakey on Sun Oct 08, 2006 6:54 pm
 The left shoulder looks a bit strange
				 shakey
 Return to Post Processing |
