perset actions in photoshop for D50
Postby aussichef on Thu May 25, 2006 4:14 pm
i was wondering if anyone who has a D50 & uses CS2
If they had some lab ,hue/sat & or level setting they save & load for portraits & landscapes
help would be much appreciated
warren
Nikon D50/D80 Nikon,MB-D80 70-200 2.8 VR,Sigma 18-50 2.8, Kenko 1.4x TC, 2 kit lenses ,Nikon 50mm f1.8 Nikon SB-600 Tamron 90mm 2.8 Canon 500D closeup lens
aussichef
Location: Port Vincent , and Tanunda South Australia,Australia
Postby NJ on Thu May 25, 2006 11:15 pm
i have a d50 and cs2, but i dont use presets, i adjust everything manually until i get it looking how i want through using brightness/contrast, saturation and curves.
Postby big pix on Thu May 25, 2006 11:43 pm
each image, one at a time, should be PP to get the best results......... unless you shoot in a controlled lighting area ie: studio, or the same lighting outside, then you can batch process.......
happy for the comments, but
big pix
Postby Sir Tristram on Fri May 26, 2006 11:45 am
Hi Aussiechef, I use a D50 and CS and very new to this game but I have found that every single photo I take is different. About the only standard thing I apply to all my photo's is just a hint of unsharp mask and all about the same level.
And this is where I met the leprechaun - He told me to burn things
Sir Tristram
Postby Johnnie Hurrah on Fri May 26, 2006 3:06 pm
I have a D50 and CS2. I agree with all of the above. Perhaps the only time you might use a preset or a "batch" setting would be a group of shots with the same subject and exposure. The camera RAW dialog in CS2 allows you to apply changes (quite selectively) to multiple similar images.
Johnnie Hurrah
Johnnie Hurrah
Return to Post Processing
