| Tutorials, questions, demos, questionable images ,,,
			Forum rulesPlease ensure that you have a meaningful location included in your profile. Please refer to the FAQ for details of what "meaningful" is.
			 by stubbsy on Tue May 16, 2006 12:37 am
 This is a quick lesson. If you need more detail I can oblige, but I want to point out something often overlooked in Photoshop and that is the Transform tool.  The first image below is the original shot. Below it is the final shot after PP and cropping.
 Here's what I did after opening the image:
 Select entire imageEdit/Transform/PerspectiveDragged top left edge to make the doorway appear more square (pulling top left also causes matching movement on top rightDouble click image to apply effectSelect entire image againEdit/Transform/Distort. Chose this because the image still was a little trapezoidal to the rightPulled top right down a little and tinkered till doorway now appeared squareDouble click to applyFinal PP involved a brightness/contrast layer to lighten the inside, some cloning to remove distracting edges (like the speaker box) and a tight crop
Moderator Posts: 10748Joined: Wed Dec 08, 2004 7:44 pmLocation: Newcastle NSW - D700
 by Paul on Tue May 16, 2006 1:31 am
 Cheers Stubbsy!
 Just been fixing some Harbour bridge shots I took last year where the towers looked like the leaning tower of Pisa!
 It all looks great now!  Nikon F80D, FM2nRRS BH-55, 055XPROB
 Smugmug
				 Paul
Senior Member Posts: 866Joined: Tue Nov 23, 2004 8:32 amLocation: Baulkham Hills, NSW,  Australia
 by PiroStitch on Tue May 16, 2006 1:35 am
Senior Member Posts: 4669Joined: Sat Mar 05, 2005 1:08 amLocation: Hong Kong
 by spada on Tue May 16, 2006 6:43 am
 Thank Peter for the tip, I have lots need to be fixed     Regards
 Spada
				spada
			Member Posts: 375Joined: Sun Feb 13, 2005 6:55 pmLocation: Riverwood Sydney   Age old Fuji S2
 by huynhie on Tue May 16, 2006 9:06 am
 Very cheeky Peter. I was tring to figure out how got the perspective square when you where shooting inside the Church in Newcastle.
				 huynhie
Senior Member Posts: 1476Joined: Wed Jan 19, 2005 12:11 pmLocation: Sydney
 by stubbsy on Tue May 16, 2006 9:31 pm
 Hope you found this useful.
 Moved to Post Processing section
 by ABG on Tue May 16, 2006 9:51 pm
 stubbsy wrote:Hope you found this useful.
 Very useful.  Thanks Stubbsy.Andrew
				 ABG
Senior Member Posts: 689Joined: Mon Nov 14, 2005 1:53 pmLocation: Oatley, Sydney
 Return to Post Processing |
