New Canon 50D
New Canon 50D
Postby zafra52 on Sat Sep 20, 2008 12:30 pm
As you all possibly would know Canon came up with the 50D, which is the successor of the 40D. From what I read, it will take the same lenses. What is the general view? Are there enough improvements to justify an upgrade from the 30D to the 50D? More importantly, do you think the technology in the 50D will produce similar quality images of the D700?
Re: New Canon 50D
Postby gstark on Sat Sep 20, 2008 2:33 pm
Yes, we do.
It's being discussed in this thread.
And this one is closed.
And now I shall reopen this. I missed a little "0" ....
My apologies
Re: New Canon 50D
Postby DaveB on Sat Sep 20, 2008 8:20 pm
zafra52 wrote:Are there enough improvements to justify an upgrade from the 30D to the 50D?
Only you can decide. Because I had the option to dispose of my 30D, I upgraded from the 30 to the 40, and have been very happy with it. There are incremental improvements from the 40D to the 50D. To recap some of them, have a look at DPR's list of 30D/40D differences and 40D/50D differences.
I'm considering upgrading my 40D to 50D only because I want to take best advantage of my upcoming Antarctic travels. Otherwise I'd probably stay with the 40D (and I might still do so).
I would suggest that the improvements from the 30D to the 50D make an upgrade worth considering, but the 30D still takes nice photos and you need to decide for yourself.
I guess that depends how you measure "quality". I wouldn't try too hard to compare 50D images to the D700, nor to the 5D.
Apart from the basic issues of number of pixels, noise levels at various ISOs, etc, there's the fundamental difference of 1.6x-crop to "full frame": the difference in the resulting magnification of the image projected by the lens means the way the DOF produced by the lens is drawn in the final image is a bit different.
There are so many factors to consider when comparing cameras: handling, image quality, high ISO performance, etc. If you're just looking at image quality at "normal" ISOs (up to 1600) I'd suggest that the 5D (Mk.I) and D700 will produce similar images. They're both full-frame so issues of lens/DOF behaviour are equivalent. And the 5D is a lot cheaper (although not quite as cheap as the 50D yet). But there are things that the D700 does better than the 5D: it's not all about the image quality with the cameras on tripods pointing at static subjects...
DaveB
Re: New Canon 50D
Postby devilla101 on Sun Sep 21, 2008 10:26 am
zafra52 wrote:As you all possibly would know Canon came up with the 50D, which is the successor of the 40D. From what I read, it will take the same lenses. What is the general view? Are there enough improvements to justify an upgrade from the 30D to the 50D? More importantly, do you think the technology in the 50D will produce similar quality images of the D700?
To me personally, yes I do think its a worthy upgrade from the 30D. I love my 30D and whenever I require a faster camera and need that 1.6x crop factor the 30D is what I grab. Looking at the 50D it is a sweet upgrade since it nearly (not all) incorporates some of the Mark III features and then some. I'll be looking at this and the 5d mkII when they get properly reviewed.
devilla101
Re: New Canon 50D
Postby zafra52 on Sun Sep 21, 2008 11:17 am
Thank you all for the information. Now I have to start saving!
Re: New Canon 50D
Postby robert on Mon Sep 22, 2008 10:56 am
Just seen the listed price on Discount Digital- $1800. Its a couple hundred more than I expected- i guess the price will probably come down a bit once they are readily available.
They also have the D90 at $1470, this is more like the price I expected for the 50D.
Due in a week (29th Sept)
Robert
Robert
robert
Re: New Canon 50D
Postby rmp on Mon Sep 22, 2008 2:07 pm
Given the choice between better lenses on a 40D and non-L lenses on a 50D, go for the better lenses.
May not be applicable to your particular situation, but as a general rule not a bad principle.
Robert
rmp
Return to Canon Corral
