Nikon lens mount for Canon cameras
Postby Grev on Wed Feb 01, 2006 11:57 am
Does anybody know where to get the mount that can convert Canon cameras into the Nikon F mount and therefore being able to use the Nikkor lenses?
I assume it's not advisable to put the mount on yourself, right? :lol:
Grev
Postby Big V on Wed Feb 01, 2006 12:09 pm
Ebay has them..you put the
adapter ring on the
lens, then mount it to the camera...
Canon
Big V
Postby greencardigan on Wed Feb 01, 2006 12:29 pm
Big V wrote:Ebay has them..you put the
adapter ring on the
And lose metering/focusing??
See adapter HERE on Ebay
greencardigan
Postby gstark on Wed Feb 01, 2006 1:01 pm
adapter ring on the
You would lose metering, and auto focussing.
The lens would still be able to be fucussed manually.
I personally wonder why somebody would want one of these: I suspect that you'd be losing more than you'd gain.
Postby Grev on Thu Feb 02, 2006 12:28 am
Well to me they're novelty items, "I have a Nikkor on my 350D!! Now you can't criticise me for being a brand loyalist!!" type of thing. :lol:
Grev
Postby DaveB on Sun Feb 05, 2006 12:38 pm
Actually, you still have metering. In Manual mode the camera's meter will work. Because the camera has no way of controlling the lens' aperture, Tv-priority and P modes do not work. But Av-priority should work fine. You set the lens aperture and the camera will set the shutter speed to suit.
If an adapter doesn't allow this then it's not triggering the microswitch that lets the camera know a lens is attached. This can be worked around, but good adapters will do this for you.
I'm actually considering one of these adapters, and the reason is that there are some speciality lenses available in the F-mount. Not your usual lenses, but the funky UV-Nikkors are ones that spring to mind...
But in general I would agree with Gary that you're better off getting a lens with the appropriate electronic linkages.
DaveB
Postby gstark on Sun Feb 05, 2006 1:36 pm
DaveB wrote:Actually, you still have metering. In Manual mode the camera's meter will work. Because the camera has no way of controlling the lens' aperture, Tv-priority and P modes do not work. But Av-priority should work fine. You set the lens aperture and the camera will set the shutter speed to suit.
Good point, Dave.
Thanx.
Postby MCWB on Sun Feb 05, 2006 1:59 pm
DaveB wrote:But Av-priority should work fine. You set the lens aperture and the camera will set the shutter speed to suit.
Just to state the obvious for anyone considering this, with G-type Nikkors you can only use them wide-open in this arrangement. :)
MCWB
Postby jdear on Thu Mar 02, 2006 10:46 am
I wouldnt complain using a FF canon with my nikon WA ais lenses :)
J
jdear
Return to Canon Corral
