Nikon FE Trip REPORT!
Re: Nikon FE Trip REPORT!
Postby CraigVTR on Wed Apr 15, 2009 11:19 pm
Sorry Patrick, it seems I just gave your camera to Russell. :oops: I will replace the battery tommorow, should I try another shot?
Craig
CraigVTR
Postby Reschsmooth on Thu Apr 16, 2009 12:10 am
CraigVTR wrote:should I try another shot?
I am thinking the shutter should have closed so another shot shouldn't be required.
Our mug is smug
Postby CraigVTR on Thu Apr 16, 2009 7:03 am
Cool. :D
Has anyone seen Foonji in the last couple of days?
Craig
CraigVTR
Postby gstark on Thu Apr 16, 2009 9:35 am
CraigVTR wrote:I took my shot a couple of hours ago but may have stuffed it. Set the apeture, shutter speed, wound on the cf card, cocked the winder, poked myself in the eye with said winder, pressed the shutter release, click...... :?: :shock: ......shit the mirror has not dropped back into position. The 64 cent question is did the shutter close or jam open? :cry:
Although it's too late to check now, a quick look up the throat of the camera would ascertain that. I think you can still remove the lens even with the camera like that. Moving the dial to M90 was the correct action, however.
It sounds to me as if the exposure may have been set for a more extended time. If this occurs, and you're not expecting it, then what you've seen is exactly what would happen.
A couple of quick checks for you: camera dial set to A, lens mounted and cap removed: put the camera to your eye, pop the film wind lever to its open-at-rest position. In the viewfinder, the green needle should be on A, the black needle should be visible, and moving up and down the indicated shutter speeds as you move the camera through different scenes. If this happens, then the battery should be fine.
Apart from M90, which is a mechanical shutter speed, the camera should not function with a flat battery.
Postby gstark on Thu Apr 16, 2009 9:43 am
Reschsmooth wrote:
CraigVTR wrote:Russell do you want me to replace the battery first?
The batteries were new when I sent it in January however, it is feasible that the meter had been left on at times over the last 3 months.
The meter should turn itself off after 16 seconds, IIRC, even when the film winder is left standing proud, precisely to prevent the battery draining. Lightly pressing the shutter release turns it back on.
CraigVTR wrote:Has anyone seen Foonji in the last couple of days?
This is Patrick's call, but my inclination would be, in order to expedite matters, to bypass Foonji and move on to the next person. The two days timeframe was agreed to by all participants way back when, and It's disappointing for all to see it being ignored.
Postby CraigVTR on Thu Apr 16, 2009 9:49 am
Exposure was set at 125 @f11, all manually set. This camera has nearly identical controls to my old Ricoh xr2s so the layout was familar and the problem was also familar. A low battery would still operate the meter with the black needle moving in the viewfinder as you described but not allowing the mirror to drop after the shot. Anyway, I will replace the battery and forward the camera on as soon as I hear from Foonji.
Craig
CraigVTR
Postby Reschsmooth on Thu Apr 16, 2009 9:54 am
Craig, if you don't hear from Foonji by early afternoon today, can you send it on to the next person. I would suggest PM'ing that person not to get their details just in case. This way, the camera should get to the next person by tomorrow so they have the weekend to take their shot.
Our mug is smug
Postby CraigVTR on Thu Apr 16, 2009 10:04 am
Patrick
Pm sent to Geoff. Will check on this arfos post times.
Craig
CraigVTR
Postby CraigVTR on Thu Apr 16, 2009 3:15 pm
The camera is in the post to Geoff.
Craig
CraigVTR
Postby Geoff on Fri Apr 17, 2009 9:14 am
Excellent - if it arrives today, I will get a shot over the w/e and send it to the next person first thing Monday.
Postby Geoff on Mon Apr 20, 2009 12:55 pm
Not at the post office today :(
Hopefully tomorrow.
Postby Reschsmooth on Mon Apr 20, 2009 1:25 pm
CraigVTR wrote:The camera is in the post to Geoff.
Hi Craig
Can you confirm that you sent the camera via express or registered post to Geoff as he has not received it yet.
Original rules for FE camera wrote:3. Only Express or Registered post can be used, and the person shipping the camera each time pays for postage (if you don't want to pay, that's fine, you just can't participate).
Our mug is smug
Postby ATJ on Mon Apr 20, 2009 2:35 pm
SIGH! :evil:
Postby Ant on Mon Apr 20, 2009 3:36 pm
:agree: And to think I felt bad because I had it over a long weekend.
Ant.
Ant
Postby Geoff on Mon Apr 20, 2009 7:02 pm
Craig sent it to me via registered post on Thursday. It's understandable to be frustrated but this time it's no one's fault except Aus Post.
Postby CraigVTR on Mon Apr 20, 2009 7:12 pm
It was sent express pony post on Thursday. Sometimes things from up here are very slow to arrive.
If it has not arrived tommorrow I will go back to the post office.
Craig
CraigVTR
Postby Pa on Mon Apr 20, 2009 8:29 pm
hi Craig is there a tracking number for it
cheers pa
http://pa.smugmug.com
Pa
Postby CraigVTR on Tue Apr 21, 2009 7:31 am
Checked the tracking number and it says delivered on Friday morning.
Craig
CraigVTR
Postby Geoff on Tue Apr 21, 2009 11:32 am
Damn - I've just come back from the PO BOX, nothing in there again (no card even to say it's waiting for collection).
I will head back to the Post Office later in the day.
Postby Pa on Tue Apr 21, 2009 12:10 pm
I think you might have to sign for it
cheers pa
Pa
Postby Reschsmooth on Tue Apr 21, 2009 12:15 pm
Pa wrote:I think you might have to sign for it
I think Geoff is saying that there is no indication that the camera has been delivered.
I presume it was sent to the correct address? Aust Post don't have a stellar reputation for sending the items to the correct address.
Our mug is smug
Postby Geoff on Tue Apr 21, 2009 12:42 pm
Correct Pa.
Although I just looked online and it says it's arrived at the Post Office.
17/04/2009 08:50 Delivered WARRINGAH MALL POST SHOP
17/04/2009 04:48 In transit FRENCHS FOREST DF
it's now the 21st and I've had no notification of delivery..I will check it out later in the day..Bloody AUS POST!
Postby ATJ on Tue Apr 21, 2009 12:44 pm
I don't believe you have to sign for Express Post items. They will just deliver them.
I know with our "Post Office" they frequently forget to leave a card in our PO Box and we have to ask them if they have a package for us.
Postby Geoff on Tue Apr 21, 2009 1:19 pm
Thanks Andrew,
Whenever I have received express post items in my PO Box, I always get a little card, for the past 3 years that is.
Postby Geoff on Tue Apr 21, 2009 3:36 pm
Good News! I now have the FE!
I hope to get out this afternoon and take a shot and forward it on to the next person TODAY.
AUS POST had incorrectly sorted it and had put the notification card in the wrong PO BOX...grrrr.
Geoff.
Postby Reschsmooth on Tue Apr 21, 2009 3:42 pm
Excellent, I assume Craig should be entitled to a replacement express post bag given it wasn't delivered within 24 hours?
Our mug is smug
Postby Geoff on Tue Apr 21, 2009 3:51 pm
Reschsmooth wrote:Excellent, I assume Craig should be entitled to a replacement express post bag given it wasn't delivered within 24 hours?
I asked about that Patrick - it was actually delivered to the PO the next day, but not to the correct person. I guess if you wanted to argue the point with them you could, but I was in a hurry and just wanted to get out of there.
Paul's next..yes?
Postby Geoff on Tue Apr 21, 2009 5:25 pm
Image taken and the FE is back in the postal system on it's way to Paul.
Reference no. PN6117203.
He should receive it tomorrow, Wed April 22nd.
I think I took the 19th exposure and did not wind it on after pressing the shutter release.
Postby Ant on Tue Apr 21, 2009 5:51 pm
I think this trip report is becoming almost as interesting as the photos. :lol:
Ant.
Ant
Postby Reschsmooth on Tue Apr 21, 2009 5:53 pm
Geoff wrote:I think I took the 19th exposure and did not wind it on after pressing the shutter release.
What did you set the white balance at? :biglaugh:
Thanks for the prompt hand-pass.
Alicia just emailed me saying she found a roll of film at home with "FE for DSLRUsers project" on it - you reckon I should have loaded that into the camera? Wouldn't y'all love that? :biglaugh:
Our mug is smug
Postby CraigVTR on Tue Apr 21, 2009 6:25 pm
Glad to hear the camera arrived safely. Good old Aust Post Storage. :twisted:
Craig
CraigVTR
Postby Geoff on Tue Apr 21, 2009 7:17 pm
White balance? No I just balanced it in my hands really :D
Postby gstark on Wed Apr 22, 2009 3:27 pm
Geoff wrote:Thanks Andrew,
Whenever I get an express post delivery, they deliver the little card, without ever trying to deliver the bloody item! The card says I can pick the item up at the l;ocal PO ... after 4-bloody-30!
That's express non-delivery, Bondi style.
Postby Geoff on Wed Apr 22, 2009 10:04 pm
Paul got the camera today too.
Postby Paul on Sat Apr 25, 2009 10:56 am
Dropped the FE off at David's (Dviv) this morning.
Frame count is at 18 and requires to be cocked for next image.
Nikon F80D, FM2n
RRS BH-55, 055XPROB
Smugmug
Paul
Postby dviv on Tue Apr 28, 2009 3:26 pm
Shot taken over the weekend and Camera handed over to Yi-P today.
(Thanks for meeting me half way Yi-P) :cheers:
dviv
Postby Reschsmooth on Tue Apr 28, 2009 4:10 pm
What's going on - it has been a week and the camera has now passed onto the 4th person since Geoff received it? :D
Good work guys. :)
Our mug is smug
Postby Mr Darcy on Tue Apr 28, 2009 4:14 pm
Reschsmooth wrote:What's going on - it has been a week and the camera has now passed onto the 4th person since Geoff received it
Dare I say it?
It's not in Queensland anymore :twisted:
Postby CraigVTR on Tue Apr 28, 2009 5:14 pm
Dare I say it?
We did have flodds get in the way, as well as Australia Posts pony express post. :nono:
Craig
CraigVTR
Postby Reschsmooth on Tue Apr 28, 2009 6:48 pm
Dare I say it?
You can't just lay it on the Brisvegans - the Melbournites played a hand.
But, that said, accepting that this still has to go via Wendell, :roll: we are nearing the end, and we can move on from any discussions about tardiness and look forward to seeing the results. Just hope I get it back before Junior 2.0 makes a showing so I will time to develop and have scanned (the film, that is).
Our mug is smug
Postby Yi-P on Wed Apr 29, 2009 12:51 am
Winded the camera to exposure #20, and ready to get out to take a shot whenever I see one... :P
Postby Geoff on Wed Apr 29, 2009 5:59 pm
Don't delay Yi-p - get out there and find a shot! :)
Postby Reschsmooth on Sun May 03, 2009 9:56 am
Hi Yi-p, how are you going with the shot and sending it on to Wendell?
Our mug is smug
Postby Geoff on Mon May 04, 2009 6:58 am
Yi-p??
In the words of Leyton Hewitt..."come onnnn!".. :)
Postby Pa on Mon May 04, 2009 9:15 am
:lol: Well said Geoff
cheers pa
Pa
Postby Yi-P on Mon May 04, 2009 4:01 pm
I'm just waiting for Wendell to reply.
Postby gstark on Mon May 04, 2009 4:15 pm
He's probably wendelled his reply button. :)
Postby Reschsmooth on Mon May 04, 2009 4:35 pm
Yi-P wrote:I'm just waiting for Wendell to reply.
If you don't hear from Wendell by midday tomorrow, we can try Foonji who missed out further up the order. PM him now and if he also doesn't get back to you by midday tomorrow, you can send the camera to me and we can finish this exercise.
Our mug is smug
Postby Reschsmooth on Wed May 06, 2009 9:33 pm
Yi-p - what is happening?
Our mug is smug
Postby Pa on Fri May 08, 2009 4:56 am
Two working days Yi-p not 2 weeks
cheers pa
Pa
PreviousNext
