Photography In A Nutshell
For beginners, and everyone else as well.
Postby gstark on Tue Apr 19, 2005 9:00 pm
Thank you to Matt K for all the work on another tutorial to add to our supply.
Postby Soulboy on Tue Apr 19, 2005 9:01 pm
Oops - Page not found :(
Or am I just to quick for ya? :wink:
Soulboy
Postby gstark on Tue Apr 19, 2005 9:03 pm
Try again; you were a tad too quick
Postby Soulboy on Tue Apr 19, 2005 9:04 pm
it's there now.
Thanks Gary, Thanks Matt K :)
Soulboy
Photography in a Nutshell
Postby Byron on Wed Apr 20, 2005 10:01 am
Matt K
Thankyou for sharing your vast knowledge in such an easy to read format, very helpful for someone who is still fumbling around with her camera.
Tamara
Byron
Postby Manta on Wed Apr 20, 2005 10:03 am
Thanks Matt, from another 'fumbler'. :wink:
Postby Bandit on Mon Jun 06, 2005 7:34 pm
I echo that comment.... extremely useful for a novice!
Jamie
All those who believe in telekinesis, raise my hand.
Bandit
Postby Colcam on Tue Jul 11, 2006 5:09 pm
Article is not at http://www.d70users.net/files/PHOTOGRAP ... TSHELL.pdf
Any ideas guys?
Col
Photography. The Art of Seeing, Not Just Looking
http://www.frozentime.com.au
Colcam
Postby Mal on Tue Jul 11, 2006 5:12 pm
Colcam wrote:Article is not at http://www.d70users.net/files/PHOTOGRAP ... TSHELL.pdf
Any ideas guys?
Col
Mmmm yep it's gone. I think the last person to see it was BANDIT , please bring it back :)
Mal
Mal
Postby birddog114 on Tue Jul 11, 2006 5:14 pm
Pls. look at the left side of our front page under TUTORIAL.
birddog114
Postby gstark on Tue Jul 11, 2006 5:15 pm
Col,
The correct link should be homed from our dslrusers.net domain rather than our older D70users.net one.
COuld you please make the appropriate substitution and let me know if that works?
Could you also point me to where you took the link you used from, so that we mak correct the reference so that others don't have the same hassles?
Postby gstark on Tue Jul 11, 2006 5:17 pm
And Thanh's observation is absolutely correct: the link from the site's front page is correctly homed, so if you use that one, there should not be any problems.
Postby Mal on Tue Jul 11, 2006 5:18 pm
gstark wrote:Col,
Gary I took the link from your link at the top of this thread
is that the issue?
Mal
Mal
Postby gstark on Tue Jul 11, 2006 5:27 pm
Mal,
Thanx for that.
I've edited that message, and so both links are now correct.
Postby Glen on Tue Jul 11, 2006 5:34 pm
Matt, very succint and useful guide. Thanks
Postby Colcam on Tue Jul 11, 2006 5:36 pm
Okay guys. I originally hit the link at the top od this page and nothing. I was logged in to the .com version due the bounce from the reminder emails which send me to the .com site rather than the .net and when accessed from the centre of the main page http://www.d70users.net/files/PHOTOGRAP ... TSHELL.pdf , I get the Not Found page.
If I log on to the .net site & go to it from the Tutorial section at left of the main page http://www.d70users.net/files/PHOTOGRAP ... TSHELL.pdf all is well.
Too many sites AARRGGHH! :shock:
I will get there. Just wondering about the effect on newbies??
Col
Colcam
Postby Glen on Tue Jul 11, 2006 6:03 pm
Col, just so your links don't confuse anyone, here is the correct link: http://www.dslrusers.net/files/PHOTOGRA ... TSHELL.pdf from Gary's corrected link at the top of this thread, as stated a few posts ago
Postby gstark on Tue Jul 11, 2006 7:50 pm
Colcam wrote:Okay guys. I originally hit the link at the top od this page and nothing. I was logged in to the .com version due the bounce from the reminder emails which send me to the .com site rather than the .net and when accessed from the centre of the main page http://www.d70users.net/files/PHOTOGRAP ... TSHELL.pdf , I get the Not Found page.
Col
Col, I need you to be specific regarding where the incorrect links are.
For instance, the first that you mention in what I've quoted ... that's coming from within a message, and thus it lives within the message database.
That's the link that Mal pointed me to earlier this afternon, and if you check it now, it should be correct, regardless of whichever site you access it from.
Please do not confuse that though with other references to that same link that will exist within this message thread, which I have not edited, and therefore will be, and will remain, wrong. The only one I've fixed thus far is my original link, as pointed to by Mal. Again, that's the one that's at the top of the previous page, and it's embedded within my message.
Now, you say that some of the links from the front page are working, but you then go and quote an incorrect link. That confuses even me. :)
I checked one of those links earlier this afternoon, before Mal made his post, and that was fine. But the link was not what you've quoted here.
Please understand that the links on the front page come from a totally different source, and are individually sourced within each of the sites. Thus it's possible that they might, occassionally, get out of synch, but that's why I need to know exactly which one it is that is not resolving correctly, if that is in fact the case. Basically, I can't fix it if you can't tell me where it's broken. :)
Postby Colcam on Wed Jul 12, 2006 9:08 pm
<snip> Basically, I can't fix it if you can't tell me where it's broken. :)
I first went to the link on the very first message in this thread and it didn't work, but the front page links (Tutorial Section) did. It would appear that the link works now. I may have been thinking about it and writing message when you were correcting it. I cannot remember now whether I was logged in from a topic reply noification email (.com login) or through a .net login. Any way the link that wasn't working before now is. Sorry to cause you any drama. :oops:
Col
Colcam
Postby emilmh on Fri Jun 08, 2007 10:40 pm
thanks alot for the info!! Very informative and i like how you have given some scenarios and examples of situations. You have summed up alot of complex info in a really simple and readable manner!
Emil
emilmh
Postby Louie on Sat Jun 09, 2007 10:20 am
Yep, this newbie really appreciates the tutorials in this site!
Managed to find them okay, still learning how to apply them :D
Elena
Louie
Postby adamj123 on Thu Jul 12, 2007 6:16 pm
Thanks for that tutorial, very informative.
adamj123
Postby Big Monkey on Sat Jul 28, 2007 7:04 pm
Thanks for such a informative yet easy to follow and learn document. It is great to see these things when you are a newbie like me! :oops:
Big Monkey
Postby Chaase on Thu Aug 09, 2007 1:43 pm
Matt
Thank you for provding this reference, as a total newbie this type of tutorial is invaluble as is this website.
Bruce
Chaase
Postby Matt. K on Thu Aug 09, 2007 8:24 pm
My pleasure! :D
Return to Tutorials
