There was no filters on for this shot.
Lens Flare / ReflectionsModerators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
Lens Flare / ReflectionsI have seen this occur on the nikkor 17-55 a few times in the 12 months that I have owned this lens, any ideas on how to aviod it..? anyone else have similar problems?
            There was no filters on for this shot. ![]() gerry's photography journey
 Re: Lens Flare / ReflectionsHi gerry, reviews for the 17-55 often point out that its prone to lens flare. So its not just you.
            No idea on how to fix it though. D80, 50mm F/1.8, 18-70mm DX, Sigma 10-20mm
 Re: Lens Flare / ReflectionsNot that I think it would have solved the problem but, were you using a lens hood?
 affirmative gerry's photography journey
 Re: Lens Flare / ReflectionsFilter? if so get rid of it....
   I took some night shots with a 50 1.4 once, and had a uv filter attached. A bright part towards the middle of the picture was reflected upside down. I had never had any issues using this lens in the daytime (with or without filters)... I have since taken night photos with the same lens (no filter attached this time) and not had the issues, so would definitely agree that the filter does cause issues (esp at night) Russell
		Nikon D700 // 50 1.4 // 70-200 2.8 VRII // 24-120 f4// Tamron 90 // SB-800 // 70-300G I'm on Redbubble too ... http://www.redbubble.com/people/rflower If you can make one of my photos look better and you have the inclination ... please do so.
 Except - as said there was no filter on at the time.
 Re: Lens Flare / ReflectionsIt looks like the flare is from the lights on the bridge, so I don't think there is much you could have done to avoid it short of using a lens that doesn't flare as much.  Given the light sources are in the frame, I don't see that you can stop the lens bouncing that light around if that's what it's prone to do.
 Re: Lens Flare / ReflectionsLOL i missed that! Cameron
 Re: Lens Flare / ReflectionsWhat if you opened the aperture up Gerry? Would it be more blurry so that the flare is less noticable?
 Re: Lens Flare / ReflectionsI wonder if it's the anti-flare coating on the lens.
 I will remember that for next time..I typically wander around the f8 mark, however will try it out.. gerry's photography journey
