Photo Editing Software - NewbieModerators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
Photo Editing Software - NewbieHi all,
Just want to get your thoughts/advice on photo editing software for a newbie. I have had a go of Photo Shop CS2 and found it very difficult to understand and use to it's full potential. What other programs are available that are user friendly? I have also had a go with Paint Shop Pro X2 and found it relatively good. Your thoughts and suggestions would be appreciated. Cheers Big Monkey
Re: Photo Editing Software - NewbiePhotoshop elements 6 is a "dumbed down" version of photoshop. It pretty much has auto stuff though.
Nikon D7000
Re: Photo Editing Software - NewbieWhat camera do you have (this can make a difference)? What specifically do you want to be able to change with your images?
There are loads of applications out there and they all have their strengths and weaknesses depends on what you specifically want to do. For example, if you have a Nikon camera, CaptureNX will do a fantastic job on the raw conversion and also let you change most things (white balance, exposure, contrast, highlights, etc.) but won't let you add water marks. It also allows you to edit metadata but is pretty clunky for that purpose.
Re: Photo Editing Software - NewbieThanks guys
I have a D200 and sb600 atm. I will probably use it mostly for colour enhancement, adding borders, white balance, exposure, contrast and touching up. Just looking for a program that won't break the bank, but still be usefull. Not sure about the Raw side of things, as I only shoot Jpegs atm. But this will hopefully change! Cheers Big Monkey
Re: Photo Editing Software - NewbieIf you are only shooting JPEG, PaintShopPro will do all that you want and is fairly easy to use (although I should say that versions of PSP up to 9 very pretty good and then Corel nobbled the later versions).
You should really consider shooting raw as it is much more forgiving and you have much more scope for edits. CaptureNX is the best raw processor for Nikon cameras and will do all the things you list except adding borders. Lightroom is worth a look - you can get a 30 day free trial - although it is not great for raw conversion*. There are downloadable presets for D200 which will help with the raw processing. * Just to clarify that comment. Lightroom uses Adobe Camera Raw which is a very powerful raw processor. Its main failing is its default processing of raw images.
Re: Photo Editing Software - NewbieThanks for your advice!
I am downloading CaptureNX as I write this. Will also give lightroom a go as well. Cheers Big Monkey
Re: Photo Editing Software - Newbiethis freeware may be handy for you also,i use it to do borders and frames, it also does the other stuff you want.
Might be worth a look http://www.photoscape.org/ps/main/index.php Nikon D7100/D7200, Nikkor 18-55, Nikkor 55-300, Nikkor 30, Nikkor 105 macro, Nikkor 10 - 24, Tokina 11 - 16, Tamron 150-600mm, SB600, Misc other
Return to Absolute Beginners Questions Who is onlineUsers browsing this forum: No registered users and 11 guests |
