HELP! My CPL broke off!
Postby Yi-P on Sat Sep 16, 2006 12:50 am
I went out today for some shooting with the CPL.
After using for about 1 hour, rotating it all rounds for different angles and effects, it eventually snapped off from the ring!! :shock: :shock:
Anybody here knows how to fix this?? :cry:
Postby sheepie on Sat Sep 16, 2006 7:36 am
snap it back in :)
Mine did the same when "someone" dropped it - luckily there was no damage to the glass, so I just put it back together. The metal ring is all that holds it in place - may not have been seated properly to start with, and the heavy use may have disturbed it enough to come loose.
sheepie
Postby Oscar on Sat Sep 16, 2006 7:44 am
Is it covered by warranty? when did you buy it?
Oscar
Postby gstark on Sat Sep 16, 2006 8:39 am
Mick,
This isn't worth worrying about under warranty. As Leon says, just snap it back in.
There's no issues of optical alignment in play here. Just a piece of glass that has come adrift from its mount. It's a somewhat common occurrence: i've seen it on a couple of occassions.
Postby Yi-P on Sat Sep 16, 2006 8:52 am
I tried to put it back on for start, but then all the oil lubricant is now over the rings... :(
I will just keep trying for now, thanks for letting me know its 'common' issue with CPL filters, im a bit reliefed now. :)
Postby gstark on Sat Sep 16, 2006 9:32 am
Yi-P wrote:I tried to put it back on for start, but then all the oil lubricant is now over the rings... :(
That can be cleaned off.
Postby Yi-P on Sat Sep 16, 2006 6:19 pm
Thanks Gary for fixing my CPL today at the workshop. Now time for some serious cleaning on the filter :)
