well going to Monarto is alot cheaper and you do not have to worry about DVT..
| Cheap Africa Trip...Moderators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
			Forum rules Please note that image critiquing is a matter of give and take: if you post images for critique, and you then expect to receive criticism, then it is also reasonable, fair and appropriate that, in return, you post your critique of the images of other members here as a matter of courtesy. So please do offer your critique of the images of others; your opinion is important, and will help everyone here enjoy their visit to far greater extent. Also please note that, unless you state something to the contrary, other members might attempt to repost your image with their own post processing applied. We see this as an acceptable form of critique, but should you prefer that others not modify your work, this is perfectly ok, and you should state this, either within your post, or within your signature. Images posted here should conform with the general forum guidelines. Image sizes should not exceed 950 pixels along the largest side (height or width) and typically no more than four images per post or thread. Please also ensure that you have a meaningful location included in your profile. Please refer to the FAQ for details of what "meaningful" is.
		 Cheap Africa Trip...      well going to Monarto is alot cheaper and you do not have to worry about DVT.. Canon
 mine are coming, hopefully the male running shots look as goodon screen as they do on the lcd. Please don't use or edit my images. D200x2, kit lens, Sigma 105mm f2.8, Nikkor 50mm F1.4, SB600, SB800, Sigma 70-200 f2.8, Sigma 1.4x TC, 2x TC, Sigma 120-300 f2.8
 Nice shots Big V.
 I can't help thinking they should be a bit warmer. They might be accurate but I think they could do with a bit more warmth. Daniel Nikon D4, D2Xs, D70, Nikkors and Sigmas lenses from 10 to 400mm www.DSAimages.com
