My favourite.Moderators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
My favourite.I haven't posted this image on here before and I came across it whilst trying to find my favourite shot of 2006.
![]() "The good thing about meditation is that it makes doing nothing respectable"
It is.
Few comments.
What is the subject on this picture? If it’s the bird, it’d be better if you created a slight angle when taking a picture and placed the bird slightly to the left of the frame – this is known as the rule of thirds – rather than having the stick and the bird sticking out of the middle. Create shallower DOF to isolate the bird from surroundings. At greater angle, the bird will be looking in open space in front of it and there will be no dead space left behind. The stick will create a diagonal line on your image. You can put the bird in the middle of the frame and very close but then why do you need distracting background with greater DOF? Instead, fill 80% of the frame with the image of the bird. That way you will have more balanced image within the frame. Here’s an example. Another participant posted his image on this forum: http://members.westnet.com.au/stetner/D ... _Kooka.jpg If your intent was to show spectacular background with some clouds in the sky, the horizon and red dirt then don’t put the bird so close on the frame, it distracts the view of the landscape behind. Put the bird further away, level the image of the bird with the horizon and take a picture of landscape. You will get a nicer image of the sky and landscape. How did you get so close to the bird focal length of 24mm? I tend to agree with another respondent; this image is the composition of two other images. The composition of the picture is below average and over sharpening is unnecessary. It’d be more pleasing to view the image with rich contrast colours in mid-tone range and softer light. That's my opinion.
Joey read my post above. It is indeed a composite from two images. The bird was shot with the 80- 400 VR from memory at 400mm. Your other comment are noted but have nothing whatsoever to do with what I was trying to create. But thank you for your critique.
