3 sb800's
3 sb800's
Postby wendellt on Wed May 31, 2006 1:53 pm
hi
thought i should share some technical mumbo jumbo on my recent fred bare kidswear fashion shoot
on the last afternoon of shooting i foudn myself without a outdoor studio strobe light that i was using for most of the shoot it had to be returend to the rental place before the end of the day, so in a haste to take advantage of the afternoon light my lighting guy and assistant Bozidar Dimovsky devised a 3 flash system to mimic the light output from a bigger strobe light
we used manual mode set to 2 metres max output and 2 of them slaved to 1 master then taped up the 3, even arranged in parallel
all units sensed each other and all fired at the same time, but i think there was slight lag
as demonstrated here
ta da...
one of our members kevin kopson(Mitedo) came along to take candids
as you can see this properly exposed photo shows the time of day as it were with a blue sky around 5:00pm
theres Boz holding the units
now credit goes to member MCWB, Thankyou trent and i think someone else i can't remember for suggesting to use ND filters to darken the scene without upping f stops
otherwise i would have to shoot at f16 or higher and use a higher shutterspeed than the sync speed on the sb800's which is 1/250 otherwse i would of got dramatic flash output dropoff
in order to get the moody shot i wanted at that time of day i used a Neutral Density x8 to darken the whole scene shot at f8 ISO100 and used a shutterspeed of 1/250 in sync with the flash units, the units were set on max output, the nd filter neutralised the background the high output of the flash compensated for the lighting on the model(close range) and I got this
later in post i changed the colour balance to 5700K to get the warmer feel
this is another one shot available light no flash metered for the model background overexposed but stil llooks moody and nice
there were probably easier ways to get the same results but this was our way.
Postby Nnnnsic on Wed May 31, 2006 1:59 pm
But the last shot doesn't work and it would take a hell of a lot of curves control to get it anywhere near right.
Nnnnsic
Postby rokkstar on Wed May 31, 2006 2:05 pm
Interesting Wendell. Nice effects - i should get some ND filters.
Wouldnt you get the same effect by underexposing the background by 1 or 2 stops and using the d2xs FPS setting to sync at higher speeds, allowing you to open up the aperture?
Matt
rokkstar
Postby wendellt on Wed May 31, 2006 2:13 pm
rokkstar wrote:Interesting Wendell. Nice effects - i should get some ND filters.
yes
but i wanted to keep the depth of field high at f8
and even if you set the d2x to ignore the 1/250 flash sync barrier you will get flash output drop off so either Boz would have to get into frame hold the flashes closer to the model or i had to add more flashes
i wanted to minimize differential focus effects for this shoot
so no wide apertures used for the entire shooti kept it around f8
when i used the strobe the ir trigger for thed2x could only sync at 1/125 shutterspeeds over that did not trigger the strobe remotely, this caused lots of technical constraints
Postby Raskill on Wed May 31, 2006 2:19 pm
Wendell, great images mate. You have the reputation on this board that you deserve.
Thanks for sharing your techniques also. Ithink you might be the only member who owns 3 Sb800's!
http://www.awbphotos.com.au
Raskill
Postby birddog114 on Wed May 31, 2006 2:23 pm
Raskill wrote: Thanks for sharing your techniques also. Ithink you might be the only member who owns 3 Sb800's!
I think he has two and lost one recently!
I have 4x SB800s + 01 x SB80DX.
And not too often use them, I shoot with fast primes mostly.
birddog114
Postby Raskill on Wed May 31, 2006 2:26 pm
Yeah but Birdy, your spoiled and have WAY to many toys.
:lol: :wink:
I like fast primes, but you don't have a spare 200-400 VR do you? :wink:
Raskill
Postby wendellt on Wed May 31, 2006 2:27 pm
thanks raskill i share my technique becuase lots of people on this forum helped me outi'm trying to give back the knowledge
anyway birddog
i have 3 sb800's i lost one
bought another for the fred bare shoot - retail, sorry i didn't go through you brdy but i needeed one post haste
i knew i may need one as soon as i foudn out rental hire closed 5pm on the friday and that was the last day of the shoot, otherwise we would have had to rent lights over the weekend just to cater for the friday afternoon
Postby Nnnnsic on Wed May 31, 2006 2:27 pm
No such thing as "way too many toys".
Nnnnsic
Postby Raskill on Wed May 31, 2006 2:29 pm
Nnnnsic wrote:No such thing as "way too many toys".
Very true mate, as they say, "he who dies with the most toys, wins"
:D
Raskill
Postby birddog114 on Wed May 31, 2006 2:30 pm
Raskill wrote:Yeah but Birdy, your spoiled and have WAY to many toys.
:lol: :wink:
Yes, if you want to have a play with it (200-400VR), I can loan it to you few days on my way to Mudgee next week, subject to a suitable meeting point.
Condition: You have to show me your insurance policy with it on :lol: incase your other half misunderstood and thought you're going to play with fire :shock: :lol:
birddog114
Postby smac on Wed May 31, 2006 2:38 pm
Wendell, I'm gonna get me one of those triple SB800 units and strap it to the front of my 4-wheel drive to use when I go off-road......shooting kangaroos......
Oh....that's right I have never been off road with my 4-wheel drive.......might scratch the rims. Scrub that idea
Perhaps I could strap it to my roof and scare the shit out of all of those P-Platers doing 80km/h in a 50 zone.......
Stuart
'Tis better to have loved and lust than never to have lust at all.
smac
Postby Nnnnsic on Wed May 31, 2006 2:39 pm
You could strap it to the roof and fire it randomly and people might think they've been caught speeding.
Nnnnsic
Postby birddog114 on Wed May 31, 2006 2:42 pm
smac wrote:Wendell, I'm gonna get me one of those triple SB800 units and strap it to the front of my 4-wheel drive to use when I go off-road......shooting kangaroos......
Stuart
Stuart,
Have you seen this thread?
http://www.dslrusers.com/viewtopic.php?t=17772
Good time to try out your X5, on the sand, nothing harm to it. and the road is very cleared of bushes and plants.
Yes, get few of the SB800 and mount it to the X5's bumper bar, great spot lights heh?
birddog114
Postby wendellt on Wed May 31, 2006 2:43 pm
Stuart
stuart you are implying the light output form those 3 units must f been mega bright, butit wasn't it just provided enough light for that time of day, model wasn't dazed or anything that's why i had her close her eyes just in case
Postby losfp on Wed May 31, 2006 2:45 pm
Nice one, Wendell - I really like it (first shot, the second one made my eyes hurt!!!)
I need to get a darker ND filter. I made the mistake of getting a 4x filter, and then discovering that in most cases, I'd like it darker :(
losfp
Postby rokkstar on Wed May 31, 2006 2:48 pm
I see.
So were you using iTTL metering for the flash or did you set the output manually? I would have imagined that 3 sb800's together could be bounced off the moon and still light up Telstra stadium. THose bad boys are bloody bright.
Matt
rokkstar
Postby wendellt on Wed May 31, 2006 2:51 pm
rokkstar wrote:I see.
not during the daylight, most ofthe flash was drowned from the bright daylight and the ND8x
i shot in manual mode 2 metres fstop f2, there was a slight delay on the slaves so i think flash output was reduced slightly because the 2 slaves did not fire exactly at the same moment the master oen did and a 1/250 i think some light was clipped, but the results show, we tested with 1 sb800 same settings light output was lower
Postby sheepie on Wed May 31, 2006 3:17 pm
How come you didn't make use of the iTTL?
sheepie
Postby wendellt on Wed May 31, 2006 3:26 pm
sheepie wrote:How come you didn't make use of the iTTL?
because that woudl of normalised the exposure
i was taking a styled shot i wanted it to look a certain way i had to control falsh output to get the desired result not rely on the camera automatic metering to get what you see is what you get sort of shot
Postby gstark on Wed May 31, 2006 3:36 pm
losfp wrote:Nice one, Wendell - I really like it (first shot, the second one made my eyes hurt!!!)
Fold it in half, Des. :)
Postby losfp on Wed May 31, 2006 4:16 pm
gstark wrote:Fold it in half, Des. :)
Well Gary, in the meantime, I AM stacking it with a CPL, which gives about the same result... Not so flash at 12mm on my Tokina 12-24, but that's the price you pay :)
losfp
Postby tarotastic on Thu Jun 01, 2006 10:38 am
That third shot is awesome. Great lighting and a sublime expression you have caught on the face of the little lady. Nice one, geezer.
D70S
tarotastic
Postby MATT on Thu Jun 01, 2006 11:31 pm
Thanks for this insight, interesting how you achieve your results.
Thanks for sharing
MATT
MATT
Postby Grev on Fri Jun 02, 2006 2:42 am
Nice little tutorial. ;)
Grev
