Capture NX v1.0.1 update
Postby gooseberry on Fri Sep 01, 2006 10:50 pm
A lot of issues addressed in this release
Windows
Mac
Issues addressed with Capture NX Ver. 1.0.1
* Support for RAW images captured with the D80 has been added.
* Batch process speed has been increased.
* An issue that sometimes caused an error to occur when several hundred images were processed in a single batch process has been improved.
* An issue that prevented display of information in the Camera Settings palette when both the Camera Settings palette and Browser were opened after opening an image in an image window has been resolved.
* When Open in Split Window... was selected from the Browser's Folder menu icon and an additional browser window was opened, the File Directory palette of the additional browser window could not be opened with File Directory palette of the original browser window open. This issue has been resolved.
* An issue that caused Control Points to change position, with the following procedure, has been resolved.
o When the Automatically move pointer to the default button in a dialog box checkbox was checked in the Pointer Options panel of the Mouse Properties dialog opened from Control Panel > Mouse under the operating system.
o A Control Point was placed over an image with Capture NX and that Control Point's Settings palette was undocked from its fixed position with Docking button and then closed.
o The Control Point's Settings palette was reopened by clicking on the existing Control Point.
* When multiple images were selected, and View menu > Compare > Compare in Browser or Compare in Editor selected with the Browser undocked from its fixed position with a click of the Docking button, Capture NX failed to respond. This issue has been resolved.
* An issue that prevented display of English fonts, when printing with the following procedure, has been resolved.
o When Print... was selected from the File menu.
o The Meta Data... button clicked in the Print Layout dialog.
o One or more options in the Print Information area of the Meta Data dialog was selected for printing and the Font area's Change... button clicked.
o A Japanese font, such as Mincho, was selected from the list in the Font dialog and the OK button clicked.
* When the Run process immediately radio button was enabled in the Watched folder panel of the Batch process Settings Options dialog, batch processing was not performed on images inside sub-folders, despite the Include subfolders checkbox having been checked. This issue has been addressed.
* An issue that caused an error to occur when one Color Control Point was dragged to a position inside the effective range of an adjacent Color Control Point has been resolved.
* The following issues that occurred when using Capture NX while logged into a user account with a name consisting of 2-byte characters have been corrected.
o The color profile was not displayed under Current Profile in the Settings palette displayed when Color Profile... was selected from the Adjust menu for an image once edited and saved and then reopened in an image window.
o When Color Profile... was selected from the Adjust menu and the Convert to Profile option selected in the Settings palette, the histogram in the Photo Info palette was not displayed.
o When Color Profile... was selected from the Adjust menu and a color profile selected from the pulldown menu in the Settings palette, display of the Current image was completely black when Compare > Compare with Original was selected from the View menu.
* When the Use thumbnail data (Draft use only) checkbox was checked in the Print Layout dialog for printing an image selected from the Browser and then choosing File menu > Print..., the image was not printed properly. This issue has been resolved.
* An issue that prevented display of data and time when an image was printed to a file, with the following procedure, has been resolved.
o Print... was selected from the File menu and the Meta Data... button clicked in the Print Layout dialog.
o The Date only and Date and Time options in the Meta Data dialog were selected.
o The Print to file option in the Print Layout dialog was selected and the Save button clicked.
* An issue that prevented selection of a specified area when the + button was clicked and then the - button clicked, or vice versa, for the Lasso tool in the Lasso & Marquee toolbox has been resolved.
* After a NEF image was edited using an enhancement such as Levels & Curves and then saved and closed with the Opacity option in the Edit List selected, the dialog stating that the image has been modified and asking whether it should be saved now is displayed when the NEF file is reopened and then closed without any editing having been performed. This issue has been resolved.
* An issue that prevented proper output when a RAW image captured with the D1X was selected in the Browser, with 6MP (3008x1960) selected for D1X raw default in General tab of Preference dialog, and then printed or output to file has been resolved.
* An issue that prevented display of the Agree button label displayed in the Software License Agreement screen with installation has been resolved (Swedish version).
* When one or more images were selected from the Browser and Save As... chosen from the File menu, an issue that prevented the image(s) from being saved at the specified JPEG quality (saving in JPEG format only) setting has been resolved.
* A lack of returns in the text of the License.txt file, after installing Capture NX, has been resolved (Korean, Simplified Chinese, and Traditional Chinese versions).
gooseberry
Postby Matt. K on Fri Sep 01, 2006 11:50 pm
Apart from the above it works perfectly.
Postby gooseberry on Fri Sep 01, 2006 11:53 pm
Matt. K wrote:Apart from the above it works perfectly.
:lol: :lol: :lol:
gooseberry
Return to Important links
