Tip #504
Tip #504
Postby biggerry on Fri Oct 12, 2012 8:49 pm
I need very few words for this tip.
check your f@#%ing date on the camera and make sure it has the right year. I never really cared about the daylight savings..but changing the year on 10 months worth of images is...painful - actually that leads me to the second part of the tip
Photomechanic can actually batch change the capture date on images, quite neat. Oh yes, whats that you say? of course LR can do that too...but it does not change the file, just the catalogue :x
Tip #504
Postby Wink on Fri Oct 12, 2012 9:00 pm
I think it can change the file if you set it to write the changes to xmp.
Adam.
MY PHOTOS
Allows Image Editing
Wink
Re: Tip #504
Postby Remorhaz on Fri Oct 12, 2012 9:25 pm
biggerry wrote:date on the camera and make sure it has the right year
Or just buy a new camera every year :?
Re: Tip #504
Postby biggerry on Fri Oct 12, 2012 9:42 pm
Wink wrote:I think it can change the file if you set it to write the changes to xmp.
yeah and you can set the checkbox in the cat settings to write to raw file - and it appears to work - so I stand corrected :up: LR for the win and now i just need to delete all those silly xmp files.. (that will take me just as long) :wink:
hows that gonna make me set the correct date? thats just gonna burn a fing big hole in my wallet :rotfl2: and to boot i will probably still forget to change the date.
Re: Tip #504
Postby photohiker on Fri Oct 12, 2012 10:35 pm
biggerry wrote:Photomechanic can actually batch change the capture date on images, quite neat.
Gerry, how do you find PhotoMechanic?
My LR Catalog is clogged with all the images I took but didn't quite measure up. Never seem to get around to removing them. I'm wondering if inserting Photomechanic into the workflow would improve things. I watched a video somewhere showing that it gave very quick review and easy moving of keepers for later LR processing.
Be interested to hear what you think.
photohiker
Re: Tip #504
Postby biggerry on Fri Oct 12, 2012 10:45 pm
I only downloaded the trial to have a crack at it, however i did immediately find it quite intuitive and particularly fast for reviewing and managing images, i did not delve into the full DAM side of things nor the processing side. From the very little research I did - people often insert it into the workflow for that very reason you mentioned - really quick culling and managing. oh and changing the date on the exif data on a large batch of images.
I reckon just download the trial and have a go, its a pretty lightweight program and gets some good reviews around the traps. Sorry I can't be of more help :(
Re: Tip #504
Postby Remorhaz on Sat Oct 13, 2012 7:07 am
biggerry wrote:hows that gonna make me set the correct date? thats just gonna burn a fing big hole in my wallet and to boot i will probably still forget to change the date.
Well - if it's a "new" camera it will a) by default have a date starting at the current year so you're good already and b) the initial setup you're forced to do on first turn on makes you set the date - see a win win :)
Re: Tip #504
Postby aim54x on Sat Oct 13, 2012 8:58 am
Default year is usually the year of firmware release.... but the initial set up will get you there...how did your D7000 get set with the wrong year Gerry?
Return to Tips and tricks
Users browsing this forum: No registered users and 20 guests
