UV Filter on Canon 70-200 f2.4 II USM
Postby Chaase on Sat Apr 09, 2011 10:51 pm
Well I got a Canon 70-200 f2.8 II lens a couple of weeks and ago and have been very disappointed with it as all shots taken have not been as sharp as I would have expected.
Today whilst out with the family and still not being able to get decent shots even on fully automatic, in desperation I tried some shots without the genuine Hoya UV filter.
With filter
Without filter
With filter
Without filter
The last 2 images have been heavily cropped.
To my surprise the camera & lens came alive. Is this common, is there something I am missing. The filter on this lens used to be on my Tok 12-24 (shots taken with it here viewtopic.php?f=18&t=34237)
I read on one forum that UV filters are no longer necessary and to use clear glass instead. I would appreciate ppls thoughts
Bruce
Cheers, Bruce
Edit photos OK.
Chaase
Re: UV Filter on Canon 70-200 f2.4 II USM
Postby aim54x on Sun Apr 10, 2011 12:48 am
Can I ask what sort of filter you are using?
It is true that we could go bare lens, but if you decide to go down the route of a filter then you should get something good.
There is a very interesting article that compares a whole bunch of filters.
http://lenstip.com/113.1-article-UV_filters_test.html
Postby DebT on Sun Apr 10, 2011 7:31 am
I had a similar problem that affected sharpness - turned out the piece of filter glass (expensive top quality filter ) was cross threaded on it's mount so did not sit parallel to the lens glass , after we finally worked out the problem the store swapped it for another , now no problem
DebT PS Great review thanks Cameron
DebT
DebT
Postby Chaase on Sun Apr 10, 2011 5:22 pm
The filter is a Hoya HMC UV(c) and it is not cross threaded :(
I have just ordered two HOYA 77mm 77 PRO1D PRO1 Digital CLEAR Protector Filter for my L series lens's so I will see how they go. I would not imagine there will be an issue with them.
Cheers, Bruce
Edit photos OK.
Chaase
Postby aim54x on Sun Apr 10, 2011 10:12 pm
Chaase wrote:The filter is a Hoya HMC UV(c) and it is not cross threaded.
That is strange, the HMC filters (silver box) are highly regarded, and test as well as the Pro1D's in that comparison. I personally use B+W XSP MRC and Marumi DHG
Postby photohiker on Sun Apr 10, 2011 10:17 pm
Isn't the answer self evident?
A filter adds something between the subject and the sensor. It can have a small effect, or a very large effect as evidenced by this example.
Add filters when you need them...
photohiker
Postby Chaase on Tue Apr 12, 2011 9:13 pm
photohiker wrote:Isn't the answer self evident?
It was most noticeable at full zoom as per the photos. I want a piece of glass on the end for protection purposes due to my ineptness at times. Hopefully the HOYA 77mm 77 PRO1D PRO1 Digital CLEAR Protector Filter will live up to it's reviews.
Cheers, Bruce
Edit photos OK.
Chaase
Return to Tips and tricks
Users browsing this forum: No registered users and 17 guests
