Difficulty searching for lenses on forum "Search"
Forum rules and nettiquette, along with other items of general interest.
Important information about this forum is contained here, and members MUST familiarise themselves with the posts here, as well as what is contained within the FAQ.
Please do not complain if you ask a question regarding a topic covered here or in the FAQ and in response you get a rather brusque, obtuse or sarcastic response. We get sick and tired of answering the same questions, day in, day out, when the answers are clearly published, in plain view, and all that is required is for you to open your eyes and read them!
Postby georgie on Tue Dec 09, 2008 11:24 am
Hi,
I am having difficulty finding posts about different lenses under the search facility. I have read the FAQ and tried different combinations but can't get it to work.
I try for instance "18-200" and I get no results but if I use "200" I get many results with the 18-200 in it.
Any suggestions at all? I am sure I am doing something simple that is wrong..
Many thanks
Georgie
georgie
Re: Difficulty searching for lenses on forum "Search"
Postby Mr Darcy on Tue Dec 09, 2008 12:11 pm
I am sure you will soon get a reply from some one who actually knows, but many search engines use a simple joining scheme so you can make more complex searches. If this is indeed enabled on this forum,
18-200 would be interpreted as "containing 18, but not 200" exactly NOT what you want
You could try 18+200 which would return threads with both 18 and 200 in them
Also you could try putting the entire string in quotes:
"18-200" which would then match that exact string, but would not find 18 - 200 for example
Postby ATJ on Tue Dec 09, 2008 12:15 pm
Mr Darcy wrote:You could try 18+200 which would return threads with both 18 and 200 in them
Greg,
I was going to suggest exactly those so I tried them first. They don't work and I can't explain why. I do understand how the "-" wrecks things, but it appears there's no way around.
I should add that the other problem with search is that it requires at least 3 letters. "18" only has 2 which may be why things don't seem to work.
Postby ATJ on Tue Dec 09, 2008 12:21 pm
Using +18 +200 seems to work, but it will match on any 18 and any 200, but only when both exist in the same topic. i.e. it would match on 18-200 but also on "18-70 and 70-200"
Postby georgie on Tue Dec 09, 2008 12:24 pm
Thanks for the suggestions guys.
Will give them a go :D
Georgie
georgie
Postby sirhc55 on Tue Dec 09, 2008 3:05 pm
Using the search function is akin to being in the middle of the Simpson without a compass :shock:
Postby ATJ on Tue Dec 09, 2008 3:22 pm
sirhc55 wrote:Using the search function is akin to being in the middle of the Simpson without a compass :shock:
I don't need a compass to watch The Simpsons. :roll:
Postby dviv on Tue Dec 09, 2008 3:56 pm
ATJ wrote:I don't need a compass to watch The Simpsons. :roll:
Especially not a moral version :mrgreen:
dviv
Postby photohiker on Tue Dec 09, 2008 4:37 pm
You might find google advanced search against this site to be a little more powerful
Like this
Of course, as you can see, people putting their gear in their signatures generally stuffs up searches...
HTH
photohiker
Return to Information
