Being asked to login againModerator: Moderators
Being asked to login againBoth before and after we moved to the new version of the forum software, I have not had any issues with Firefox and the forum remembering my credentials and I never have to log in to the forum - even after not being connected for a week or rebooting or anything. Until now...
I have just moved to a new laptop for work. Now the forum is asking me to log in as little as 2 hours after I last used it. I don't have to log in within a session so it appears to be some kind of timing thing. It is obvious that it is some setting on the new laptop, probably in Firefox, but I have no idea where to look. The Privacy settings look correct: and I can see cookies from both dslrusers.com and dslrusers.net Anyone with any ideas?
Re: Being asked to login againI can't help, but am looking forward to seeing the solution as I've had this problem since we migrated to the new look - if I close dslr and reopen it even 10minutes later, I still have to log on again
At least I can still remember my password I spose Dodging and burning are steps to take care of mistakes God made in establishing tonal relationships! -Ansel Adams
Re: Being asked to login againRel,
Do you normally connect to dslrusers.net or dslrusers.com? I'll have to boot up the old one to see what I connected to, but on the new machine I have been connecting to dslrusers.net and I'm now wondering if that might be the problem.
Re: Being asked to login again.com is the default site that you should be connecting to. The new version of the software doesn't seem to handle the multiple domains as well as the older version.
Re: Being asked to login again Yep, was logging onto .net ... have now changed to .com and logging on perfectly - thanks Andrew & Gary
Thanks, Gary. As I typed my post and looked at my cookies I suspected that it was a .com/.net thing. What is odd, though, is the notification emails are sent by dslrusers.net and sometimes have links to dslrusers.net and sometimes dslrusers.com (I suspect based on whatever the user was using to create their thread).
Not odd at all. Because the sites have moved between physical hosts over time, I have used different domains to transition from one to the other with minimal disruption to the sites. The emails are only set up to come from the .net domain, as that was the domain that was the original target domain at the current host (DH). Links within threads will be, as you have discerned, based upon the domain to which the user creating the link has logged in to. g.
Re: Being asked to login againGary,
This is what I was referring to:
I guess if someone responds to a post on .net, the link in the email include .net and if they respond on .com the link included .com.
Perhaps, but my thinking is that the forum name, as set in the configuration, is .com, hence that is what is initially quoted in the email. The links though show the .net domain because when you registered to watch the thread, you would have been (as you have already observed) logged in to the .net domain. What happens if you unsubscribe to the thread, and then, being logged in through.com, then subscribe to it, or some other thread? I'm presuming that you'll get one as a result of this post (and you probably already have from some of my earlier ones) in which case those posts of mine would have been made by me in the .com domain. g.
Both of those quoted emails are for this thread so it can't be based on what I was using when I started watching the thread as I haven't changed my subscription. The first one I received at 9:28am and so corresponds to your post (I assume on .com). The second one I received at 9:07am which would be for Rel's post when she was using .net. I actually switched to .com shortly after my original post (as it dawned on me that might be the cause) but still received emails with .net (other threads, too).
Re: Being asked to login againWhich then seems to corroborate your suggestion then.
Interesting to know. Cheers g.
Re: Being asked to login againI also have these sorts of issues.
When I go direct to the site I go to .com but I usually go to the site via an email link. Sometimes I get asked to log on. Sometimes I go in as logged on. I can already be logged on in one tab and still be asked to log on on another. What is really frustrating is that sometimes I will be logged on, answer a post, then when I click "submit", I get asked to log on again - and lose what I have typed I am getting into the habit of copying all posts to the clipboard before submitting Greg
Re: Being asked to login againGreg,
I bet you are seeing those issues for the reasons I observed. If you go via an email link that was .net (because the poster was on .net) you have the log in problems.
What Andrew says is correct. Check your links as you accept them; I'll bet that when you're asked to log in, you're trying to access .net g.
Re: Being asked to login againYep I can see that but I can't understand, in that context, being asked to login in when I submit a reply to a post. I will track that in future.
Re: Being asked to login againVery simple: your cookies have you logged in through the one domain, but not the other.
As the software doesn't handle the cross-domain boundaries as gracefully as the earlier version, and the board configuration is that one must be a logged in member in order to post any message ... g.
Re: Being asked to login againI have always logged on to .net so have never had the auto login. Problem now solved.
Thanks guys. Craig
Lifes journey is not to arrive at our grave in a well preserved body but, rather to skid in sideways, totally worn out, shouting, "Wow what a ride." D70s, D300, 70-300ED, 18-70 Kit Lens, Nikkor 105 Micro. Manfrotto 190Prob Ball head. SB800 x 2.
Who is onlineUsers browsing this forum: No registered users and 20 guests |
