first few pics with my D80
Postby lukipelaa on Sat Oct 04, 2008 6:20 pm
still learning how to use it comments appreciated!
lukipelaa
Re: first few pics with my D80
Postby ATJ on Sat Oct 04, 2008 6:58 pm
Pretty good shots for a first timer, especially considering the harsh light. Full Sun generally not very forgiving and makes for deep shadows. The other thing I can recommend is to get closer to the subject.
Postby Matt. K on Sat Oct 04, 2008 7:34 pm
In your first and last shot the background is much brighter than your subject. This will always result in a dark subject. If you can learn to see this before shooting then your options are..
1.....change your metering mode to spot metering
2.....turn your subject around and physically move the camera postion
3......Pop up you flashgun and turn to spot metering mode
A bright background is always a trap. Next suggestion, as stated in the previous post...get much closer to your subject. That is the single most important thing you can do to improve your photography. Thanks for posting.
Postby lukipelaa on Sat Oct 04, 2008 8:41 pm
was kind of afraid i'll be labelled as a pedo if i get closer to them :P
another thing. when u guys say turning the subject around meaning have the shadows behind them instead of front?
lukipelaa
Postby ATJ on Sat Oct 04, 2008 10:46 pm
lukipelaa wrote:another thing. when u guys say turning the subject around meaning have the shadows behind them instead of front?
Well, more importantly, have the lighting at the front - i.e. so it is on the subject.
Postby paulmac on Sat Oct 04, 2008 10:56 pm
...but then the subject would be squinting in said full sunlight, or would be hiding under the brim of his hat.
In my (very) humble opinion, the lighting is pretty bloody good for the first pic. I agree about the comments about using pop-up flash though.
paulmac
Postby ewm3 on Sun Oct 05, 2008 7:09 pm
Have to agree with the others; get in closer. Try to avoid photographs at noon; they give lots of harsh shadows. Early morning and late afternoon are good. Don't be afrAID TO USE 'FILL-FLASH' in harsh light. Keep sending them in!
Eric in Adelaide
Nikon gear but looking for talent...
ewm3
Return to First Image
