Optimising a photo for Canvas printingModerator: Moderators
Optimising a photo for Canvas printingHi guys,
I've been keen to get some canvas prints done recently and about to submit some files to be printed. The question I had was, are there any post processing do's and don't if my ultimate goal is to get it on canvas? I realise that whilst the results of my processing might look ok onscreen, it's probably quite different in print - and on canvas instead of paper. Should I reduce the sharpening (eg, as canvas not being as smooth a finish as gloss paper would sharpening actually make the picture look grainier etc), or even avoid doing that "soft" look commonly used in portraits? If however it is the same as printing normal photos on glass or closer to matte paper then that makes things easier. I am planning to print portraits, and family photos in a park environment. The reason I ask is a friend sent me this link: http://www.artscow.com/Create/ShowProdu ... ductId=346 (note that it is US dollars and prices are for printing on canvas only - no frames/mounting etc yet), and thought I'd give 2 or 3 a go. Last question is, is it best to submit the files in .jpg or even the raw file? Val
Nikon D300
Re: Optimising a photo for Canvas printingTo answer the last question, you would not submit the RAW file. You would submit a TIFF or a JPG (which you have processed) which should match the size(in resolution) and proportions that you are trying to print so that they don't have to resize or change proportions or crop it.
Color profiles are a subject I don't know about. I do know that this is lab specific, meaning that you have ask the lab which profile that you use etc and try to match that. Other option is to do a test print but I am not sure whether you can do a test canvas? Perhaps the smallest size to check for color problems.
Re: Optimising a photo for Canvas printingRather than start a new topic, I think my question sits well in this topic.
Can anyone tell me what DPI or pixels per inch I should strive for when printing on canvas? I have an image that is already a crop, and a customer wants it printed on canvas 20x30". The image is currently 2024x1362 pixels, therefore it can only achieve 68 pixels per inch. Is that enough to get a good enough quality on canvas? Here is a cropped portion of the image in question. Any thoughts? I have never printed on canvas before so anyone with an opinion, it would be appreciated. Maybe I should post process it again too, looking at it again it might be a bit dark. Thoughts? http://www.redbubble.com/people/tasadam ... -echidna-1 Share what you know, learn what you don't.
my main advice would be to talk to the person who is gonna print on canvas, if they know their stuff they could answer these kind os q's striaght off the bat. However in terms of quality, in qualitative terms, canvas prints tend to 'bleed' which often allows them to be printed larger. I have had a number of images printed on canvas thru a local guy and i remember talkign about dpi and all that but do not know well enough to quote for someone down your end. I had this image (below) printed not so long ago, it was 3345x1639 at 300dpi - thats what the printer dude got and i am not sure what dpi he printed to. I got it printed to 1metre wide and it looks fine and dandy. I find having a chat to the guy and showing him the images can definitely help when preparing image files. hth gerry's photography journey
Re: Optimising a photo for Canvas printingI think Gerry has answered most questions. If the print shop is not sure, that's not a good sign.
As a simple rule, I would suggest at least 200dpi, 300 if possible. What resolution does photoshop comeup with, if you change the DPI to 200? [usually this causes the image to shrink in size)
Re: Optimising a photo for Canvas printingI was going to make a thread like this, you beat me to it.
Dont mean to hijack your thread but... Can Anyone recomend the best place in brisbane? and will printers only make the sizes to a set size, or can you choose the dimensions? Last edited by chasem on Wed Sep 09, 2009 3:32 pm, edited 1 time in total.
any printer worth their salt should print whatever size (up to printer limits) and aspect ratio that you desire. couple of other threads Re canvas: http://www.dslrusers.com/viewtopic.php?f=21&t=34154&start=0&st=0&sk=t&sd=a&hilit=canvas#p369235 http://www.dslrusers.com/viewtopic.php?f=48&t=36205&start=0&st=0&sk=t&sd=a&hilit=canvas#p385804 and FYI, the only affiliation I have with this guy is the fact that I get a fair amount of stuff printed thru him and its just down the road. gerry's photography journey
Re: Optimising a photo for Canvas printingI did a search before posting and found this topic most suited to my enquiry. Though I did find the zimprints topic, along with several others.
I have sent zimprints an email, making the full res photo available to them, and await an answer. Will let you know what they say re my resolution issue. Re printers in Brisbane, have you tried this? Hope it helps. Cheers! Share what you know, learn what you don't.
Yes i have, but i was looking for some sort of recomendations, who is good, who is bad? im sure that the printing stores wont say that their prints were/are; bad quality, took to long, wrong size, ETC. see what im getting at?
Re: Optimising a photo for Canvas printingThis might help you, perhaps, maybe.
Re: Optimising a photo for Canvas printingThanks, thats what i was looking for
Re: Optimising a photo for Canvas printinghey!
=D just a quick note to say, be careful with your image, sometimes if theres no detail or lack of detail in shadows, the printers ( mainly the epson stylus pro 9600 and 9800 series). So even when you think theres no detail in some areas and there actually is, you'll notice it. trust me, it can look like someone's blabbed all over you're beautiful image. =D just a heads up =D Canon | Sony | Panasonic | Tamron | Sigma
Who is onlineUsers browsing this forum: No registered users and 33 guests |
