Lightroom, displayed date/time and DSTModerator: Moderators
Lightroom, displayed date/time and DSTI just noticed something very scary about Lightroom. I hadn't noticed it with my D300 images because I've only had the D300 since December. Today, I imported all my D70 images into Lightroom, nearly 3 years worth. The date/time for all images shot between April and September (inclusive) are displayed as one hour ahead of what they should be. It appears that it has decided to make adjustments for DST, even though I didn't ask it to, and has gone in the wrong direction, even though it isn't needed. If I look at the images in View 6, View NX, etc. the date/time information is correct.
Has anyone else noticed this?
Re: Lightroom, displayed date/time and DSTDid you install the 1.4 version upgrade?
Adobe have since recalled the upgrade as there was an isue with times (I am not sure if what you described is the issue, just remember it had something to do with time), Anyway if you have you can revert back to 1.3, check this out - http://www.lightroomkillertips.com/2008/lightroom-14-update-is-pulled/ Hope this helps. Andrew
Re: Lightroom, displayed date/time and DSTNah, I'm still on 1.3.1.
Re: Lightroom, displayed date/time and DSTJust to make things clear, this is what I'm talking about:
Using Nikon View 6 (or just about any other software) it shows the image was taken at 10:16:33 ![]() But Lightroom says the same image was taken at 11:16:33 ![]()
Re: Lightroom, displayed date/time and DSTNote that if I deselect "Automatically adjust clock for daylight saving settings" of Windows Date and Time Properties, Lightroom displays the correct time.
![]() Is there no one else out there with Lightroom that sees this?
Re: Lightroom, displayed date/time and DSTAndrew
I believe it's actually a Windows problem and LR is doing what Windows does (or says). I've checked on my Vista and XP PCs and on both they show a file that has a time stamp of 2:24 pm on 7/5/2006 in the EXIF header with a date modified of 3:24 pm 7/5/2006 (see below). If I look at the image from NC or from iMatch they both show it as 2:24 pm. Bottom line - I'm not sure if it's a Windows bug or a LR feature ![]() ![]() Peter
Re: Lightroom, displayed date/time and DSTRight.... so LR is the only application that does this and that makes it a Windows bug?
![]() I don't understand why LR needs to do anything. The times in the EXIF data are correct and do not need to be manipulated.
Certainly something strange is going on. Windows' localtime functionality seems to throw some programs off, so not surprised that the LR devs got snared. For what it's worth, my Mac Version of LR displays the capture time correctly. Maybe the 1.4 update will fix it? Michael
Re: Lightroom, displayed date/time and DSTOK, seems it is a known problem (at least known to user but not acknowledged by Adobe): http://www.adobeforums.com/webx/.3c0590ff
Sometimes I get the feeling that Adobe put all their junior programmers on Lightroom.
Andrew You're right to be annoyed by this. My point was that Windows does the same thing eg in my example Windows Explorer shows the date modified time as 3:24 pm and the Vista EXIF display (shown in my shot) also says 3:24 pm when the EXIF says it's 2:24 pm Peter
Ah, I didn't notice that. In my case, Windows (XP) correctly shows the time as 10:16AM and the pop-up EXIF data is also shown as 10:16:33 AM. But... I think I have had problems in the past when I copy files from one disk to another using XCOPY with the /d parameter, that it copied the same files because the source and target times were out by an hour. I'll keep a close eye on things next week when we hit April. Anyway, I submitted a bug report to Adobe on this (my 3rd overall and 2nd in a week).
