Help needed for storyboard creation in Photoshop
Postby W00DY on Sat Dec 29, 2007 3:16 pm
Hi guys,
If I have three 8x10 images which I want to get printed out as a storyboard (ie: one sheet of paper) how do I best do this in Photoshop?
I tried to do it in Pro Select but it just isn't working for me. Ideally I need to create a template which I can use over and over again. How big should I make the matting?
Appreciate a quick response as I need to get this done ASAP.
:D
Andrew
W00DY
Postby jdear on Sat Dec 29, 2007 3:35 pm
Id best do it in Photoshops 'Picture package' - setup your page size, and add 3 8x10 areas (or are they called zones?) - click on the zones when you have setup the page and saved it, and then add the photos you want to appear in them individually.
J
jdear
Postby big pix on Sat Dec 29, 2007 3:45 pm
use a templet that you set up your self in photoshop....... very easy
happy for the comments, but
big pix
Postby W00DY on Sat Dec 29, 2007 3:56 pm
big pix wrote:use a templet that you set up your self in photoshop....... very easy
Hi Mate,
Yeah I think this would be the easiest way. Just not too sure on how much area I should include around the images as the matting.
Are there any framers on the forum that could provide some advice for this?
:D
Andrew
W00DY
Postby big pix on Sat Dec 29, 2007 4:02 pm
if all images are vertical, you will need a frame about 27 inch's wide by 12 inch deep........ and stock to print on about 30 inch wide or long
or do 3 8x10 prints and have a framer put it together
big pix
Postby W00DY on Sat Dec 29, 2007 4:27 pm
big pix wrote:if all images are vertical, you will need a frame about 27 inch's wide by 12 inch deep........ and stock to print on about 30 inch wide or long
The three images I have are all in Portrait mode. I was thinking something along the lines of:
32 (w) x 16 (h)
This gives a 2inch border between the top and side edges and in between the images and a 4inch border at the bottom.
Do these dimensions sound right?
I was hoping to get the print done on a single piece of paper and then get a framer to frame it (so no extra matting needed as the sheet of paper would include this).
I want to get this right the first time otherwise it could be a costly experiment :?
Andrew
W00DY
Postby W00DY on Sat Dec 29, 2007 5:40 pm
I have changed the dimensions slightly (on some advice from big pix) so my latest dimensions are:
Overall size - 17'' x 31''
Each image is 8'' x 10'' with a 1'' gap between them. There is then 2.5'' of space from top and each side (.5'' to allow for the frame) and 4.5'' from the bottom (is this too much?)
Do these sound right?
W00DY
:D
Andrew
W00DY
Postby W00DY on Sat Dec 29, 2007 6:55 pm
This is now driving me nuts :evil:
I created a new PSD file with the dimensions 31'' x 17'' at 300 pixels per inch... This gives me a canvas of 9300 x 5100 pixels...
I have then placed guides outlining where the three 8''x10'' images are to go...
I then open up one of the images crop it to 8''x10'' @ 300ppi, copy and past it into the storyboard file... I would has thought this would then fit into the 8''x10'' space for one of the images, no.
Each 8''x10'' space in the storyboard file is 2400x3000 pixels. Each image (image layer) is 2848 x 3560 (hence they are too big for the storyboard spaces.
What am I doing wrong? I know I should know this :oops: :oops: :oops:
Andrew
W00DY
Postby big pix on Sat Dec 29, 2007 6:59 pm
just resize them to fit using the transform controls and hold down your shift key so the image does not distort
big pix
Postby W00DY on Sat Dec 29, 2007 7:10 pm
big pix wrote:just resize them to fit using the transform controls and hold down your shift key so the image does not distort
Thanks mate, that did it :oops:
I am still embarrassed about how little I know about Photoshop :D
Andrew
W00DY
Return to Post Processing
Users browsing this forum: No registered users and 26 guests
