plugin help
plugin help
Postby robert on Mon Aug 06, 2007 1:14 pm
Hi all,
I posted in absolute beginners but didnt get a response so I am wondering how to use any actions/plugins that are downloaded.
Do i have to do anything to access them once i've downloaded or where would they be situated- eg on the toolbar under which drop down etc...
I am using elements 4
This page has lots but not sure how to open/use them in elelments. http://www.atncentral.com/download.htm
Thanks
Robert
robert
Postby Bindii on Mon Aug 06, 2007 1:36 pm
It depends on what you download.. some of them automatically load into the right folder for you but others you have to unzip and drag them into the right spot.. for instance a filter may have to be unzipped... then you would have to open up your program files>photoshop>filters>and drag the downloaded filter into that...
it might help if we knew which ones you need to install..
Postby robert on Thu Aug 09, 2007 4:22 pm
thanks bindii,
i wanted to try the SF colormixer- it looks like a split tone colouring, (from the link)
anyway i did alot of searching and not sure if many "free" actions are compatible with elements,
I tend to end up with a result I'm happy with nut i guess the plugin just makes it quicker!
robert
Postby Matt. K on Thu Aug 09, 2007 8:22 pm
Look at the extension of the filter...8BF or somesuch, and make sure you put the filter into the Photoshop folder that has the same extensions. :shock:
Return to Post Processing
