How to run a script to sharpen images along with..Moderator: Moderators
How to run a script to sharpen images along with..An action that runs a border I have and apply a default USM to my images. Can bridge do this? I can see it allows for 1 action to be applied, I'd like more than 1 if possible
? Thanks guys! 5D | 16-35L | 35L | 85L | 135L | 70-200F2.8IS | 580EX
My Blog - http://www.allkris.com My Flickr - http://www.flickr.com/photos/dastrix My Website - http://www.kriskeen.com.au
I create the individual actions I want to do.
1. Slight contrast curves tewak 2. USM 3. Canvas size to suit. And then create a master action, that runs each action one after the other. Then just batch that action. Works for me
That's the way I'd do it, too OR just record all the steps into the one action. If you want it to pause between each individual action (or step), just click on the little square to the left of the action (or step) and it will pause to await your changes before continuing.... Dave
When I do this, it tells me that the Border action isnt available.
I created an action that had the OPEN, USM and then played an action from a Borders set I had and it does it all bar the Border 'current action not available' 5D | 16-35L | 35L | 85L | 135L | 70-200F2.8IS | 580EX
What I can think from top of my head....
Record a new action called "my USM" something like that... - Forget about the OPEN command to use at first - open your previous USM action list and play the action again from the first step except the OPEN command - see if the steps are recorded into your new action - record additional items/steps same way as above, for your borders - once done, stop the recording and open the image then play the action once to check if working - run automate -> batch -> select your action and then choose a source/destination to open/save files from and to. photoshop should work by itself now.
Made some work arounds and its working nicely now
Trying to improve my workflow when using RAW. Just added Adobe Lightroom which looks quite nice so I hope this helps Cheers guys 5D | 16-35L | 35L | 85L | 135L | 70-200F2.8IS | 580EX
Who is onlineUsers browsing this forum: No registered users and 30 guests |
