FeatheringModerator: Moderators
FeatheringWhen performing different curves adjustment on different objects in the same picture, I understand that feathering is a useful option. Wendell suggested it in one of more C&C posts.
I have CS2 and when I 'feather', I am never sure exactly what I am doing. Therefore a few questions: 1. What exactly is feathering doing? 2. When you feather a selection, do you feather the pixels on the inside edge of your selection, or the outside edge of your selection? Thanks in advance.
1.When you feather a selection you are 'blurring' the edge of your selection, and you can vary that amount. To give you an example, get a photo, make a rough round selection of something in the image, change to the brush tool and just start painting. You'll find that there is a really hard edge where you made the selection. Now apply a feather to the selection, say 50-100 pixels for the sake of this example. Now do the same, make a selection and brush it. You'll find it blends in much more gently.
2. I believe it feathers inside your selection, but you can always inverse yuor selection if you want it to feather 'outside' where you've marked out. Hope this helps mate. Owen.
1. feathering softens the selection
in pixel terms lets say a feathered edge consists of 1 pixel all around an image now since a pixel is a square it is un even so you will get a jagged feathered edge now what feathering does depending on what value you place is soften the effect from the outlined marque, like a feather of 3 pixels will soften the effect of the edge from a range of 3 pixels away from the marque, this effect is gradual so in effect you get a soft edge so the effect on the first row of picels is lie 100% think in terms of opacity then the 2nd now is like 60% then the 3rd 30% then nothing 2. feather from the inside but this is a case by case scenario sometimes feathing from the outside edge is warranted for your purposes to fix that bird feather from the insideby 2 pixels
