D3 Firmware update 2.02Moderator: Moderators
D3 Firmware update 2.02Was anyone aware that Nikon released a D3 Firmware update in January 2010?
I only came across it by chance when I was browsing the NPS website, so I figured there might be a few other people out there that didn't know about it... Features: Auto white balance performance has been improved. Support for 64 GB memory cards has been added. When ISO sensitivity settings>ISO sensitivity auto control in the shooting menu is set to On, the Maximum sensitivity option can now be specified in steps of 1/3 EV, 1/2 EV or 1 EV, according to the Custom Setting b1 ISO sensitivity step value setting. The length of time the camera waits before adjusting focus in response to sudden changes in the distance to the subject can now be selected from 5 (Long), 4, 3 (Normal), 2, and 1 (Short) from Custom Setting a4 Focus tracking with lock-on. With the increase in the number of options for Custom Setting a4 Focus tracking with lock-on, this item will be set to 3 (Normal) after firmware upgrade. Adjust this setting as needed. A Dynamic AF area option has been added to the FUNC. button + dials (Preview + command dials, AE-L/AF-L + command dials) item for Custom Setting f4 Assign FUNC. Button (f5 Assign preview button, f6 Assign AE-L/AF-L button). When AF-ON is selected for Custom Setting a9 AF-ON button or a10 Vertical AF-ON button, the monitor now turns off when the AF-ON button is pressed, even when shooting information is displayed. When AF-ON is selected for Custom Setting f6 Assign AE-L/AF-L button>AE-L/AF-L button press, the monitor now turns off when the AE/AF lock button is pressed, even when shooting information is displayed. A Use GPS to set camera clock item has been added to the GPS item in the setup menu. When Yes is selected, date and time information acquired via connection to a GPS device is used to set the camera’s internal clock. After selecting Yes for the first time, turn the camera off and then on again to reacquire GPS data. When Enable is selected for GPS>Auto meter off in the setup menu, the time until meters turn off is now extended by up to 1 minute to enable camera acquisition of GPS data immediately after the camera is turned on, and immediately after meters turn on. (only with GPS Unit GP-1) When On is selected for Long exp. NR with shooting at shutter speeds slower than 1 s but faster than or equal to 8 s, it did not function properly. This issue has been resolved. The focus point was sometimes not displayed even when focus was acquired with playback of images captured with continuous shooting. This issue has been resolved. When some memory cards were inserted in the camera, “CHA” was displayed in the top control panel and images could not be captured. This issue has been resolved. http://www.BrettHemmings.com
D3 | D3S | A paperweight D2XS | D70s | 14-24 F2.8 | 24-70 F2.8 | 70-200VR F2.8 | 200-400 F4 | 50mm F1.4 | 10.5mm F2.8 | SB800 | SB600's | Elinchrom Lighting & Skyports | P7000
Re: D3 Firmware update 2.02Yip, I installed it the day after released, cant say Ive noticed much difference
Darren
Nikon D3 and Nikon Glass
Who is onlineUsers browsing this forum: No registered users and 12 guests |
