60's nikon F photomic how toModerators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
60's nikon F photomic how tohi guys.i just got this model at hand. it is so worn out: chipped corners, edges, gaskets replaced. i suspect it has been passed around different owners several times. question is when you wind the advance lever WITHOUT film inside, isnt it suppose to release the shutter when button is pressed? ive been doing this from other rangefinder and SLR and the shutter flicks even without film. AFAIK it's supposed to be cocked only once when you crank the advance lever. this time i can crank it many times. could there be some sort of broken sear inside or this model works like this without a film.
what other malfunctions should be aware of? TIA
Re: 60's nikon F photomic how toOccam's razor - check that the advance/rewind ring around the shutter button is set to A. If set to R, it will not cock the shutter. My versions will cock the shutter when you advance the film wind lever when set to A.
Re: 60's nikon F photomic how to What Patrick said!
Beautiful cameras though....hope this one is in working order or can be restored to working order inexpensively Cameron
Re: 60's nikon F photomic how to.
thanks for response guys. i follow Reschsmooth's tip and it's normally working . though i may have to return this anyway. it will be hard to look for other parts manufactured before i was born. other than the lenses and other accessories, this time the meter needle doesnt and never will work coz it turns out it uses a mercury type battery cell which is obsolete and prohibited. any sub will ruin the metering coz of hi volt. thanks .. till then
Re: 60's nikon F photomic how toI have a different meter head that also uses the mercury battery. However, I have substituted another battery (via the repair man) and it works alright. You can also try the "air" batteries.
Don't give up yet...If your location is still current I am sure you will be able to find someone that can help you within the camera repair community over in HK. Cameron
Return to Film and Non-Digital Imaging Who is onlineUsers browsing this forum: No registered users and 6 guests |
