Enlarger options
Enlarger options
Postby Reschsmooth on Fri Jan 06, 2012 9:00 am
This is probably not the most appropriate place for this, but, if anyone has any informed opinions, I would appreciate comments on the preference out of these two enlargers for both 35mm and 6cm film sizes:
LPL C7700 (with peripherals for about $200)
Omega Chromega C760 (with peripherals for $95 on the auction site).
Both come with 50mm lenses but I would need to purchase 75/80mm lenses.
I only plan on B&W at this stage, acknowledging they are both colour enlargers.
Our mug is smug
Re: Enlarger options
Postby gstark on Fri Jan 06, 2012 9:21 am
Either would be good, Patrick.
TBH, the Omega, if it sits at that sort of pricing, is a no-brainer decision.
What does "peripherals" mean? Timer? Safelight? Trays, tongs? Or maybe just a transformer?
Wish I had room for a wet darkroom. Then I'd need even more time ...
Postby Reschsmooth on Fri Jan 06, 2012 9:30 am
gstark wrote:Either would be good, Patrick.
Thanks Gary
Peripherals for the LPL package consist of trays, tongs, a waterbath for chemicals and some form of roller developing tank. The Omega kit includes safelight, Hauck timer, trays, easel, tongs, etc.
I failed to mention (based on my understanding and pending confirmation): the Omega will require the relevant negative carrier whereas the LPL has an adjustable carrier, I believe. Happy to be corrected.
My plan is to use one of the boys' bedrooms as a wet darkroom - I have read nothing to indicate that the use of chemicals will have any impact on small children :). Seriously, we have a space downstairs that will be perfectly ideal (or ideally perfect) for a darkroom.
Our mug is smug
Postby gstark on Fri Jan 06, 2012 9:34 am
Reschsmooth wrote:I failed to mention (based on my understanding and pending confirmation): the Omega will require the relevant negative carrier whereas the LPL has an adjustable carrier, I believe. Happy to be corrected.
That sounds reasonable to me, and suggests that the Omega will come with a 35mm carrier. That may be something to check with the sellers though; without the relevant carrier, you're just buying a copy stand without the lights. :)
And the question of how readily you might be able to get the 60mm carrier for the Omega comes to mind.
Postby Reschsmooth on Fri Jan 06, 2012 9:40 am
gstark wrote:And the question of how readily you might be able to get the 60mm carrier for the Omega comes to mind.
Well, no it doesn't but the question of whether I want to spend USD80 on said carrier, plus shipping from the US does. :biglaugh: There is the question of the 'mixing chamber' for the Omega enlarger required for 60mm negs that differs for the 35mm neg chamber. Additional questions I have posed to the vendor.
Oh, and Gary, if you come along to the coffee meet (date to be confirmed), I may have this up and running at that time, just possibly. :D
Our mug is smug
Postby gstark on Fri Jan 06, 2012 9:49 am
Reschsmooth wrote: There is the question of the 'mixing chamber' for the Omega enlarger required for 60mm negs that differs for the 35mm neg chamber. Additional questions I have posed to the vendor.
MY recollection may be wrong, but I suspect that's a question that's only relevant for colour processing, and might not be an issue while you're playing in the mono sandpit.
Hmmmm .... :)
Postby Matt. K on Fri Jan 06, 2012 6:40 pm
Omega. LPL was kind of a cheaper brand. Omega was common in professional darkrooms.
Postby Reschsmooth on Fri Jan 06, 2012 7:20 pm
Thanks Matt
I have also found an instruction manual for both the basic elarger and the dichroic head, which is good.
Our mug is smug
Postby Reschsmooth on Wed Jan 18, 2012 10:56 pm
Did my first print tonight... I am hooked. :D
Our mug is smug
Postby surenj on Thu Jan 19, 2012 12:07 am
Reschsmooth wrote:Did my first print tonight... I am hooked.
Congrats! :cheers:
Postby gstark on Thu Jan 19, 2012 10:05 am
Reschsmooth wrote:Did my first print tonight... I am hooked. :D
:bowdown:
Postby Matt. K on Thu Jan 19, 2012 10:08 am
It does that to people. Happened to me.
Postby Reschsmooth on Thu Jan 19, 2012 11:02 am
Matt. K wrote:It does that to people. Happened to me.
Not that I want one, but is there a cure?
Our mug is smug
Postby aim54x on Thu Jan 19, 2012 9:04 pm
Patrick...when can I come over to play?
Actually I have some left over Ilford MG 8x10 and maybe some 5x7 from the photo courses I did a few years back that should still be ok to use...if you want the paper let me know
Postby Matt. K on Thu Jan 19, 2012 9:37 pm
Sorry...it's terminal. :cry:
Postby Reschsmooth on Fri Jan 20, 2012 10:30 am
Don't be sorry, Matt. Happy to be bitten by the bug.
I may restructure my darkroom to another room that may provide more space. If I do, I may try to organise a printing meet. I have 3 film developing tanks so we can even organise an afternoon film shoot and development and then print in the evening when the film is dry. Perhaps. :D
Cameron, PM sent.
Our mug is smug
