Second hand D200 with some hot pixels - should I be worried?Moderators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
Second hand D200 with some hot pixels - should I be worried?I bought a second hand D200 with about 6000 actuations that was apparently bought in mid 2006, the camera seems to be in
pretty good condition. It is pretty overwhelming to use as I am completely new to DSLRs, but I am learning pretty fast. I have noticed in some of the pictures I have taken that there are some noticeable hot pixels. They seem to appear at ISO 400 and above and their number and appearance ranges from 1 or 2 white ones to maybe 3 white ones and 2 - 4 green, blue and red ones. I am wondering if this just happens to sensors as they age and I should find a way around it, or should I ask the seller for a refund and try and buy another? after doing some web research it seems that using RAW will bypass the hot pixels if you use the right RAW software, and also that the hot pixels can be remapped. Is it possible to remap the pixels out yourself or does it need to be done by a service center? A less important but annoying issue I am having is that the camera smells quite strongly of womens perfume. The manual says to only use pure water to clean it but I am wondering if there is anything else I could use that would be more effective at removing the scent without damaging the casing. Any help with these problems would be greatly appreciated.
Re: Second hand D200 with some hot pixels - should I be worried?Hot pixels are generally speaking a non-issue. You can typically only see them when you view an image at full size, and that should happen very infrequently, and even less often when printing your images. (think about the size that you print the images at)
Re: Second hand D200 with some hot pixels - should I be worried?Could you post an example?
I took this with the lens cap on at ISO 400, 1/2 second exposure. You will probably need to view it at 1:1 pixel size to see all the hot pixels. I count approximately six hot pixels, Pixelfixer software finds 19 at its lowest threshold of 200 and 10 at a threshold of 600. Is this 'a lot' of hot pixels to have? If it is an unusually high amount I may try and get a refund from the seller as I bought this based on its apparently good condition. Does having this number of hot pixels indicate that I am likely to have a problem with an increasing number of them? The perfume smell has started to fade away now the camera has been out of its box for a while. I asked in a new and used photographic equipment shop what would be good for cleaning the rubber and their technician recommended "Armor All" on a cotton bud - I think the "Multi-Purpose Cleaner" is the right one, but I am not sure.
Return to Absolute Beginners Questions Who is onlineUsers browsing this forum: No registered users and 21 guests |
