unsharp mask questionModerators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
unsharp mask questionwhat do you guys typically use for your settings with USM?
There is no fixed settings because it all depends on the photo itself. Some pics will require none, some will required a little and some even more. Check your pics as you apply and go with the one that is sharp but has not introduced ”halos”.
Re: unsharp mask question
USM stands for UnSharpen Mask?????????
OK,
so anyone got any tips or explanation of how the tool works itself? I use it, but fairly touch and go... i'd like to know how it actually works I guess body: nikon d200, d70s, f4s, f601.
yep thats what I've seen it refferred to commonly around the place? body: nikon d200, d70s, f4s, f601.
OOOOOOOOOOOOOOOOOOOOOOOOOOHH! Why would you want to unsharpen something????
This one is a basic explanation that helped me.. http://www.iforphotos.com/guides/post-processing-basics?page=0,5 or wikpedia for more detail http://en.wikipedia.org/wiki/Unsharp_mask "The "unsharp" of the name derives from the fact that the technique uses a blurred, or "unsharp", positive to create a "mask" of the original image. The unsharped mask is then combined with the negative, creating the illusion that the resulting image is sharper than the original."
In Canon lens terms, it also can mean Ultra Sonic Motor, which is the type of (internal, to the lens) motor used to drive the lens focus mechanism. If your confsued, then great; join the clubbbbbb. g.
PRECISELY what I wanted! Cheers!
the 'wonderful' world of acronyms, huh. body: nikon d200, d70s, f4s, f601.
There is a technique that is often used for nature photographs when publishing for the web: http://www.naturescapes.net/phpBB2/view ... p?t=105932
This doesn't always work, but often produces good results. You don't have to worry about the settings for USM and you just Sharpen as many times as needed to get the result you want.
Don't you just love terminology which seems completely arse-about?
Personally, I use slightly more amount than that suggested in the linked article (maybe 80% as a starting point) and slightly less than 1 pixel. But it is all about getting to know the effect settings have. I believe it is generally preferable to use the USM after resizing the image (if you are resizing) The benefits of applying USM to (copies of) the same image file 4 or 5 times and comparing the resulting images can be enormous.... say Amount 40% - 60% - 80% - 80% - 80% Pixels 0.8 - 0.8 - 0.8 - 1.0 - 1.2 (and so on as much as you like) You will soon get an idea of what does what Greg - - - - D200 etc
At the risk of stating the obvious - Smart Sharpen in the newer flavours of Photoshop is better to use than Unsharp Mask. But see my disclaimer below
I tend to use a couple of rounds of sharpening, depending upon the image.
To overcome the bluriness of the AA filter, I tend to use a fairly high Amount, with a very low Radius (0.3 to 0.4) - this is also good for very fine detail. For local contrast enhancement, another technqiue (named loamhirad) - Lo Amount, High Radius as mentioned by Photoshop expert Dan Margulis is quite popular. Finally, after all image adjustments, if I have done some resizing, I may do a small amount of sharpening to overcome the bluriness of the resizing. Sharpening in the L channel is recommended. Oh, and as Peter mentions, Smart Sharpen seems to produce slightly better results.
Return to Absolute Beginners Questions Who is onlineUsers browsing this forum: No registered users and 1 guest |
