Are all Quick Release Plates the sameModerators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
Are all Quick Release Plates the sameI'm about to buy a monpod (Manfrotto 679B) and want to attach a swivel/tilt head to it so I can get the quick release benefits (I'm looking at the Manfrotto 234RC). One thing that occurs to me is that when I get a tripod (probably a Gitzo 1227LVL) and a head for it I'd ideally want the QRP (ie the bit that stays attached to the camera body) to be the same with both monopod and tripod so lazy me can just leave it on the camera.
My fear is there may be manufacturing differences and this isn't possible. Can someone wiser than me resolve this. TIA Peter
Re: Are all Quick Release Plates the same
Ok here we go: QRP of the 234RC is the quick released plate can be only using to that head, the head cost around $59.00 from Vanbar. It's the simplest head and only recommend to use with monopod due to it's only ony way turn. When you have the G1227LVL, then difference head will be acquired to suit the nature and value of the G1227LVL. To simplified the system and avoid to duplicate your purchase : 1/ looking the ballhead with the QRP Arca Swiss type with dove tail. 2/ purchase a QRP for camera body (Camera plate) with dove tail 3/ purchase a lens foot (plate) for your Bigma with dove tail (Arca Swiss type) If you have all of them, then you can only use one head for monopod or tripod with difference setup, and also you can mount the camera body or lens(es) in a second. I recommend the L bracket for the body, thus this type will help you set the camera in landscape or portarit mode easier. Remember, once you would like to mount the Bigma on the monopod, you'll use its foot, it take few minutes to turn the screw and very hassle to take it off and install it on the camera body same as on the tripod. These processes won't stop the lens vibration on the tripod or monopod. All the QRP from Manfrotto or Gitzo do not have the dove tail style. Birddog114
Thanks Birddog
So to make sure I get it right (your Bigma references confused me a little):
- Buy a QRP to match - If I give in to lens lust and buy a big lens, buy a foot plate for the lens You lost me on the L bracket. I know its something that lets me rotate the camera through 90 degrees on the tripod, does it attach between the head and the camera or is instead of the head in cases like vertical panorama shots? TIA Peter
The L bracket was designed for the camera body and it attachs to the body for your convenience in rotating the body in landscape or portrait mode, it's also a device protect the body as well. Working with panorama, required shooting in portrait mode, and the good ballhead always come with the index for panorama http://www.reallyrightstuff.com/body_pl ... index.html You can see this ballhaed have the index for panorama shooting style at the foot of ballheads: http://www.reallyrightstuff.com/ballheads/index.html Same as the AUB http://acratech.net/miva/merchant.mv?Sc ... t_Code=ubh or the Markins: http://www.markins.com/2.0/eng/ballheads.html Birddog114
Return to Absolute Beginners Questions Who is onlineUsers browsing this forum: No registered users and 34 guests |
