Web preparation for dummies...Moderators: Greg B, Nnnnsic, Geoff, Glen, gstark, Moderators
Web preparation for dummies...Hi all,
I guess I'll have to bit the bullet and put up some pictures so I can get into the whole site again! This stresses me out greatly as I never think that anything I take is good enough to even critique and I am worried about embarrassing myself! (I guess the other side is that everyone here is quite nice and it is the best way to learn) Anyway, I have done a search and can't get anything to help me resize and prepare my images for the web. I can resize but do I need to do other things to make sure they look OK? Can someone please either let me know the best way or point me in the right direction? My pics are mostly shot in RAW and I have PS CS and NC. Thanks, Marvin
OK, heres how I do it in PSCS:
Open your image, then click on file at the top left, scroll down to "save for web" and click on that. Another window opens up with your image in it (usually too big). Go across to the bottom right corner and click on "Image Size". Type in either the width or height you want (the other will resize automatically) then click apply. I usually try to resize to around 800 x 600 pixels. Then go up to the compression quality checkbox and select a compression that gives you a comfortable file size, say less than 150k. The high or very high setting usually does the trick. You can see the new file sizes and approximate dialup download time underneath the photo. Click save and your done Last edited by johndec on Mon Dec 27, 2004 2:35 pm, edited 1 time in total.
Yeah, I muck around with them a bit, although I've found that if you try and do too much, you usually muck them up
At best you can only make a good photo better, you can't make a bad photo good. Well, maybe you can, but I'm still very much a PS novice.
My usual requirements for posting images on the web are roughly: 800 x 600 or thereabouts, and somewhere between 100-200 KB in size. I do everything I'd normally do in processing, which depends on the shot in question. I do most of this in NC. Then go into PSCS or your image editor of choice and resize/crop and compress (which you've already got the instructions for, so I won't repeat them ).
Looking forward to seeing your shots Marvin, don't be apprehensive, its all fun.
Greg - - - - D200 etc
G'day Marvin,
Don't be apprehensive about putting images up, it's the best way to learn what to do to improve your skills and your eye... The people here are very friendly and only provide constructive tips and advice, this is the friendliest forum you'll find... You can learn heaps just by posting and asking questions... Gee, I'm still a learner but having fun along the way Dunno about Photoshop CS, but you can do it in Nikon Capture via the Tool pallette #1 "Size/Resolution" function... You can go both ways with your resolution in most software packages (as in up or down in res)... Cheers, Mudder Aka Andrew
Marvin,
No need to get stressed or embarrase. This is a great forum and all helpful people with healthy criticism which helps a lot. If you think you take worse phots, wait till you see mine and you'll consider youself a pro cheers, ajax
Return to Absolute Beginners Questions Who is onlineUsers browsing this forum: No registered users and 6 guests |
