Some Winter images
Some Winter images
Postby biggerry on Fri Aug 16, 2019 3:23 pm
Re: Some Winter images
Postby gstark on Sat Aug 17, 2019 10:44 am
The penultimate one is spectacularly good the field of view looks to be a bit more than 180 degrees? And vertical?
14mm lens?
It's different, and different is good.
Postby Matt. K on Sun Aug 18, 2019 5:09 am
Brilliant as always Gerry.
Postby biggerry on Mon Sep 02, 2019 10:55 pm
gstark wrote:The penultimate one is spectacularly good the field of view looks to be a bit more than 180 degrees? And vertical?
14mm lens?
ta Gary - the bendy on is actually taken with the 24-70 @24 mm.. its a vertical panorama (landscape orientation shots) covering a bit over the 180 degrees
Matt. K wrote:Brilliant as always Gerry.
too kind Matt.
Postby ozimax on Tue Sep 03, 2019 12:14 pm
Spectacular Gerry. Concerning the first two wide angle images, are you sure you're not Ken Duncan in disguise? :) They are just as good as Ken's wide angles, if not better.
Postby biggerry on Tue Sep 03, 2019 1:49 pm
ozimax wrote:Spectacular Gerry. Concerning the first two wide angle images, are you sure you're not Ken Duncan in disguise? :) They are just as good as Ken's wide angles, if not better.
thanks Ozi, i really like pano images, there is a challenge in stitching together several images to capture the nice field of view, that said i find compositionally they are quite easy :)
I like this one, its a stitch of 3 images one with the car in it :)
Image(C) 2019 Gerard Blacklock, all rights reserved by Gerard Blacklock, on Flickr
Postby zafra52 on Tue Sep 03, 2019 7:35 pm
They are all masterful, but I prefer the very last one after the comments and the second last before the comments. :up:
Postby gstark on Wed Sep 04, 2019 7:55 am
biggerry wrote:ta Gary - the bendy on is actually taken with the 24-70 @24 mm.. its a vertical panorama (landscape orientation shots) covering a bit over the 180 degrees
Thanks, Gerry. I appreciate the response. My favourite shooting iron is the 24mm. And the 85.
But you can do some very interesting things with a very wide angle lens. Like getting in dangerously close to a moving tram, or getting your feet into a shot of a cathedral across the road in Melbourne, with the lights from a traffic light standard, over your head, also in the shot. :)
Users browsing this forum: No registered users and 27 guests
