NYE Fireworks 2017/2018
Postby biggerry on Tue Jan 02, 2018 3:18 pm
I know ya'all love firework pictures here :) Happy new year and all that stuff..
Image(C) 2018 Gerard Blacklock, all rights reserved by Gerard Blacklock, on Flickr
just a last one to detox from fireworks...
Image2018 in full swing by Gerard Blacklock, on Flickr
Re: NYE Fireworks 2017/2018
Postby ozimax on Thu Jan 04, 2018 7:05 am
Nice Gerry. I don't know how you do it, but you do it. Must be something to do with a camera or similar...
Superb.
Panasonic G9, Panasonic 12-60 F3.5, Olympus 45 F1.8, Olympus 40-150 F2.8
Postby biggerry on Thu Jan 04, 2018 1:25 pm
ozimax wrote:Nice Gerry. I don't know how you do it, but you do it. Must be something to do with a camera or similar...
Superb.
:D
most of it is about just getting out there to a half decent spot, the rest is fairly elementary..
heres some notes I wrote about capturing fireworks.. (i''ll see ya there next year ozi)
A few key things:
- tripod, yep thats pretty obvious.. but make sure its on something sturdy, sadly alot of my shots have wavey fireworks due to the camera/lens shake which was due to the place where I set the tripod, it had a bit of vibration :( and when your shooting a long way away a small amount of vibration can impact badly.
- set focus to manual and focus before the show starts.
- use a remote, either the infra-red button or a cable one, as long as it opens and closes the shutter thats all that is needed.
- if you have VR / OS image stabilisation on your lens, turn it off... gets me every time ;)
Camera settings:
Manual mode with shutter set to bulb (basically one press of the remote opens the shutter and the subsequent press closes the shutter.)
Aperture is typically f8-f14, a safe place to start is f10
Shutter speed, this is the only variable you need to control, typically most shots will be from 1 second up to 4 or 5 seconds depending on the firework display.
The shutter speed is very dependent on the fireworks and you have to watch the fireworks to see what colour/brightness they are and adjust this shutter speed as needed. Basically there is a lot of 'chimping' (set your display to show blinking highlights) and adjusting the shutter appropriately.
As a general rule always expose so that the fireworks are not 'blown out' as much as possible, once you over expose the fireworks the colour of the fireworks is gone. I typically under expose to retain the colours.
ie. for the blue fireworks, these can handle a longer shutter speed than most and hence you can get some lovely trails with these and maintain that awesome colour. Typically you can get a 3 or 4 second exposure on these.
green and white colours tend to over expose easily so anything from 1 second to 2 or 3 seconds seems to work ok.
Red fireworks typically are very bright, most of mine are from 1-2 seconds for these.
There is also a technique called 'Black Card' where you can open the shutter for 30 seconds or so and place a black card in front of the lens when there are no fireworks or very bright ones.. kinda like manually controlling the shutter outside the lens :) I have had mixed success with this and I typically opt for blending individual shorter shutter speed frames as needed. Blending is easy now in PS, simply use the 'lighten' mode on the multiple layers that you have.
HTH.
