Multiscale gigapixel photography I want one!!Moderator: Moderators
Multiscale gigapixel photography I want one!!This has just been published. Only the abstract is available for free, but there will be information on other sites.
Philip Nature | Letter Multiscale gigapixel photography • D. J. Brady, • M. E. Gehm, • R. A. Stack, • D. L. Marks, • D. S. Kittle, • D. R. Golish, • E. M. Vera Nature 486, 386–389 (21 June 2012) doi:10.1038/nature11150 Received 02 January 2012 Accepted 17 April 2012 Published online 20 June 2012 Article tools Pixel count is the ratio of the solid angle within a camera’s field of view to the solid angle covered by a single detector element. Because the size of the smallest resolvable pixel is proportional to aperture diameter and the maximum field of view is scale independent, the diffraction-limited pixel count is proportional to aperture area. At present, digital cameras operate near the fundamental limit of 1–10 megapixels for millimetre-scale apertures, but few approach the corresponding limits of 1–100 gigapixels for centimetre-scale apertures. Barriers to high-pixel-count imaging include scale-dependent geometric aberrations, the cost and complexity of gigapixel sensor arrays, and the computational and communications challenge of gigapixel image management. Here we describe the AWARE-2 camera, which uses a 16-mm entrance aperture to capture snapshot, one-gigapixel images at three frames per minute. AWARE-2 uses a parallel array of microcameras to reduce the problems of gigapixel imaging to those of megapixel imaging, which are more tractable. In cameras of conventional design, lens speed and field of view decrease as lens scale increases1, but with the experimental system described here we confirm previous theoretical results2, 3, 4, 5, 6 suggesting that lens speed and field of view can be scale independent in microcamera-based imagers resolving up to 50 gigapixels. Ubiquitous gigapixel cameras may transform the central challenge of photography from the question of where to point the camera to that of how to mine the data.
Re: Multiscale gigapixel photography I want one!!Nikon D4, D2Xs, D70, Nikkors and Sigmas lenses from 10 to 400mm
www.DSAimages.com
Re: Multiscale gigapixel photography I want one!!ahh its got terrible distortion... plus that ain't gonna fit in ya pocket.
![]() gerry's photography journey
Re: Multiscale gigapixel photography I want one!!This is a bit like the proposed square kilometre array (SKA), only smaller and for visible wavelengths.
In short, if you want high resolution the only thing that can beat aperture is more aperture. Cheers Steffen. lust for comfort suffocates the soul
