Pop-up Flash DiffuserModerator: Moderators
Pop-up Flash DiffuserGary was very kind to some of us at the dinner and handed out presents. I received a Phottix Pop-up Flash Diffuser. (Actually is it 3 diffusers, one white, one orange and one blue, plus a bracket that sits in the hot-shoe and holds the diffuser in place). It even came with a "Sony Adapter".
I took a couple of test shots this morning to see if it would work for macro and it looks like it could be quite handy. All the shots are at 1:1, 1/200s, f/16 with my 60mm f/2.8D on my D300 at ISO 200. Here's a shot with just the bare pop-up flash: Here's the same subject but using the pop-up flash diffuser: For a comparison, I took a couple of shots using my DIY soft boxes (1 and 3): In my opinion, the little flash diffuser does a pretty good job of softening the light, at least for macro work. Looks like a slight adjustment may be required for white balance. I took all the shots with white balance set to Sunlight. For some reason the shot with the diffuser on the pop-up flash was a little on the dark side (about 1 stop under). Perhaps f/16 was too small, although the camera did not indicate that there was insufficient "power" from the flash.
Re: Pop-up Flash Diffuser
Each of the diffusers in use will affect your WB, due to their own individual characteristics. it's not a problem, but just an issue of learning what those characteristics might be, and adjusting your settings accordingly.
Which sounds about right to me. Any diffuser will interfere with and reduce the light output from a light source. Often there's enough residual power in the flash head to compensate and adjust for this through the TTL and AE of the camera and flash combo, but it one is shooting close to the maximum power output already, then this may become an issue. Again, I don't view this as a problem, but more of a learning issue as is the case with any new equipment that you come to acquire. Of course, Andrew, I'm pretty sure that you're well aware of all of this, but I thought I'd mention this for the benefit of the younger, less experienced players amongst us. g.
Sorry, what I meant here was that as I was shooting iTTL, I thought the camera would indicate if there was insufficient power, as it does with an SB-800, by flashing the flash indicator in the viewfinder. It appears it does not. Anyway, f/16 is too small for the diffuser for 1:1. I got better results at f/11 and f/8. Yes, you will lose light output for two main reasons. 1) the light is being spread over a larger area and 2) the diffuser itself will absorb some light.
Re: Pop-up Flash DiffuserHere are some other shots: Some macro shots taken using pop-up flash diffuser.
Re: Pop-up Flash DiffuserI should have read this post first Andrew.
I am glad that you found this new kit to your liking. Regards Colin
Re: Pop-up Flash DiffuserI can see that there is a subtle but siginificant difference between bare and diffused. But the question is, being the advanced shooter you are, would you use it routinely? [perhaps when you want to travel light?]
Re: Pop-up Flash Diffusertop stuff Andrew, that just saved me and probably a whole stack of people, an hour in doing the comparison..
I would probably use it if I was in a hurry - it is a little faster to deploy - but doesn't give me the same flexibility on f/stop. I could only use f/16 for light subjects with it. With the SB-800 and my soft boxes I can use f/22 and even smaller for most subjects. I think the pop-up diffuser may be useful for people who don't yet have a separate flash and want to try their hand at macro. It is a handy piece of kit.
Re: Pop-up Flash Diffuser........ nice samples
any chance of some product shots of the diffuser Cheers ....bp....
Here you go:
Re: Pop-up Flash DiffuserWow, they look really handy i might have to ge one. i use a tissue and a rubberband and it is very un-professional.
A tissue and a rubber band won't really do the same job as this device. A tissue will diffuse the light to some extent but won't make the light source larger which is what you really need soften the light. With this pop-up flash diffuser, not only is the light source effectively larger, but it also moves it closer to the subject making it even larger, relative to the subject.
Re: Pop-up Flash Diffuserlooks like a must have piece of kit....... thanks AJ
Re: Pop-up Flash DiffuserHow much does one of these go for ?
Canon 50D - EF-S 17-55 f2.8 IS - EF 100-400 L - EF 50 f1.8
That's probably a question for Gary. Mine was free, but it is marked "AU$20". I'm not sure if that was the PMA price or it's what Poon will sell them for. They aren't listed on his eBay site. I guess you could buy the "original" for $37.00+$10 shipping.
Re: Pop-up Flash Diffuser$20 is the number, plus shipping.
As you're Sydney based, there's probably something we can do in terms of catching up somewhere. g.
Re: Pop-up Flash Diffuser...... maybe a bulk buy
Re: Pop-up Flash DiffuserI've gotta stop buying stuff and get a damn job first
Who is onlineUsers browsing this forum: No registered users and 60 guests |
