1st Tripod purchaseModerator: Moderators
1st Tripod purchaseI wonder if any members own this Manfrotto combination, Manfrotto 190XPROB Tripod with 804RC2 Pan/Tilt Head (Teds $270). I am thinking of getting this but wonder if this product is good in the field.
I would have been very happy with a Sherpa (Velbon $149) but the head doesn't pan without tilting! The only product I can find that will last AND pans is the Manfrotto, unfortunately I have to spend $120 more for this. Is there a tripod that has all the Sherpa benefits but pans as well? Cheers
Re: 1st Tripod purchaseA couple of questions ...
What sort of camera and lenses do you intend to use with this? Consider the weight of the body, and of the lenses in question. The head needs to be able to support them without getting a case of the droopsies, and the legs need to be able to support them, plus the weight of the head, without getting the wobblies. Consider that you also don't need to buy that head just because that's how Teds are bundling this with those legs. You can but any head, and any set of legs, and they will all, if they're of any sort of quality (and Manfrotto is reasonable quality) all fit and play well together. But there is a more important question that you need to consider: how many times do you want spend this money? Once? twice? four times? Velbon make rather nice accessories, and sturdy tripods that you will be using, year in, year out, are not amongst their best work. I'm prtty sure that if you buy the Velbon, you will eventually be buying a tripod somewhere further down the track. That makes the answer to question 2 at least twice. And it also means that whatever you spent the first time will have been wasted. So ... you need to understand your needs. Not for today, but for tomorrow. Address your needs correctly, and you'll only buy once, and you'll actually be saving money. You may also want to review other similar threads on this forum. There's this one and quite a few others too. Now, just one final point, please: if you look on the forum's front page, you will see that you need to have a meaningful location entered into your profile, and you will see that what you entered is actually not what we need. Please take a few moments to fix that up; it will be to your ultimate benefit. Thanx in advance for your future cooperation. g.
Re: 1st Tripod purchasethe 804RC2 head has a 4kg max weight rating, and the 190 legs have a 5kg max weight rating, so this tripod will serve you well for a long time, and be able to take the weight of most camera/lens setups. I am not familiar with the Velbon Sherpa, but I can tell u that the Manfrotto combination makes for a great, light-weight tripod that will handle almost any situation.
You are kidding right? Forget those overly optimistic weight ratings. The 190 could be a nice enough tripod for a P&S, but it is certainly not a "tripod that will handle almost any situation" with heavier gear. Seriously, this is a buy twice proposition. Cheers
I understand that the numbers arent sky high, but I used the 190 legs and a small ball head (486) with a graflex 4x5 large format camera and didnt have too many problems with vibrations.... admittedly leaf shutters and no mirrors slapping around might help, but it handled an older Bronica 645 just as well. I guess it comes down to an extent with technique- and I have never even extended the contre column. Unfortunately while i have been happy with this set up I havent used anything better so cant compare to more high end/ well specc'd tripods.(other than an old SLIK tripod for a really heavy camera) Robert Robert
Re: 1st Tripod purchasethis is weird, i thought i am the only one that thought of that combination. I am planning to get the combination. It comes to a total of approx $400. Still saving up for it.
Re: 1st Tripod purchaseI would think you can get it for less. Have a look around
Here you go - $279 + freight http://www.qualitycamera.com.au/product ... ts_id=3396 And that is the first place I checked - I would also suggest looking at Vanbar. Old D200+extras
Re: 1st Tripod purchasein the current camera house catalogue for 299, dunno where is trying for 400
Re: 1st Tripod purchasethe 190/488RC2 combo should be adequate for most people..
i find that i'm leaving my poor 055 at home or in the boot because its just too cumbersome to lug around. 190 legs are reasonably priced and reasonably built, strong enough to handle most basic kits + a little more IMO. as Gary noted, the usual questions apply when shopping for a tripod. do the homework, buy something that can adequately handle your gear + factor in a little more and meet your budget. to help others to help you, what sort of gear do you plan on using the tripod with? -j
Yeah, I have an aluminium 055 in the back of a cupboard somewhere. It turned out to be too heavy to cart around at something approaching 3kg bare.
Re: 1st Tripod purchaseThere's an old saying amongst photographers....the tripod you have in your packpack ia 100 time better than the one you've left at home.
Re: 1st Tripod purchaseFor those who are still looking, VanBar has the 190XPROB (newer model with easy switch to low angle) with the 804RC2 head for $269.
Re: 1st Tripod purchaseI am also looking to get a tripod too. So is carbon fibre the way to go?
Re: 1st Tripod purchaseCarbon fibre is lighter for the same rigidity, but it is more brittle (not sure this is still an issue witr)and more expensive
Your call. Pay more for less weight or pay less for more weight Greg
Re: 1st Tripod purchaseAdhoc,
Like Greg says there is a definite weight saving on a CF tripod and some experts also say they dampen vibrations better. You are looking at double the price for saving less than 1kg. I just bought a CF tripod this month after 15 years with the same old aluminium one. In my case, I Just thought it might be nice to carry a lighter tripod. When its on my back I probably wont notice the difference. I may notice the difference if travelling OS and weight restrictions become an issue. I checked your smugmug and you have some stunning images from Yunnan. It looks like you travel a bit so maybe CF will save some baggage weight. Robert Robert
Re: 1st Tripod purchaseIf you want CF tripods - like a lot of gear look offshore.
I have my eye on a Gitzo CF tripod ATM, and it is almost 1/2 price in HK compared to Aus retail. Big difference..... Old D200+extras
Thank you for your nice comments! But I actually don't travel much since I am still studying. I want to get a tripod for some ideas/themes I have in my head.
You are right about the price differences. I remember HK prices 1 year ago for a Manfrotto 190MF3 was only HKD$1800. With such a high Australian dollar, that just means you HAVE to buy offshore!
Re: 1st Tripod purchaseWhat do people think of Benro? We have been approached by a rep asking if we are interested in stocking them at the store.
Who is onlineUsers browsing this forum: No registered users and 15 guests |
