Lightroom and Nikon - RAW ProcessorsModerator: Moderators
Lightroom and Nikon - RAW ProcessorsHad a few play with LR and really like its simple interface and ability to manage large database of photos. Tho I'm not really sure about whether to like its massive database building for its own. My LR database is now somewhere over 2GB, handling over couple thousand images.
Here is a quick shot taken from my desk here and converted into JPG by 3 different software. Photoshop Lightroom, Nikon Capture 4.4 and Nikon Capture NX. LR uses its own Adobe Camera RAW converter to access/convert the .NEF files, whereas Nikon Capture uses its own Nikon algorithm to read the .NEF files. Does it really have the advantage to use first party algorithm to read the raw files? Let's find out.... The test process is relatively simple and not so scientific. A shot taken here at mid-day sun, harsh lights and shadows, with different patterns, shapes and shades in the scene that should be good enough to form a test shot. The test shot was taken with a 6MP D70 camera, manual exposed with 1/1250 @ f/5.6, WB set on Sunny and rest was as is. First up, Photoshop Lightroom. No setting or adjustment is applied, the file is simply imported into LR and exported out as JPEG on high quality. Result is pretty good, despite a slight underexposed sky and softness on the roof tiles is noticed in this one. --------------------------------- Now on to Nikon Capture 4.4, same no adjustment and editing. Simply open the NEF and save as JPEG on good quality options. This is what being captured and shown on the camera. Exposure is spot on and sharpness is excellent. -------------------------------- Last on Capture NX, same deal on the settings, saved as Good Quality. Result is so close to NC4 that there is no absolute differences seen at this level. Only thing I can see is slight tonal change on the roof/wall tiles to be brighter. -------------------------------- Summing up, all three RAW conversions did a very good job, from very obvious result in ACR the exposure is slightly under but saved some highlight problems here. Both Capture software did a great job in maintaining the sharpness in the image. I too found out that LR allows you to edit in a better dynamic range than NC in a way they have different controls over shadows, fill light, exposure and highlight recovery, which NC does not have these luxury options to adjust in few clicks, many things are buried beneath tools. Here is a comparison of 3 output at a 100% crop (click for full res): --------------------------------- After some minor edit in LR the result can be really stunning and eye-popping, time to do this is considerably less than what needs to be done in any of the NC software. I'll maybe write a bit more about LR later on when having time
Interesting stuff, YiP - thanks for posting it.
I've had a bit of an on-going battle to find a RAW converter that really works for me. So far, I've found the Nikon editors to produce the best results with least fiddling every time. However, I find them really slow and painful to use. I really like the ACR/LR workflow idea and I would use that in a flash if I could get colours that I was consistently happy with. For general landscape shots, I haven't found too much difference between the results (or maybe I'm just more willing to accept slight variations) but for people shots, especially in funny lighting conditions, I've really struggled with ACR/LR - no amount of fiddling and calibrating gives me the results I want, yet the Nikon software does this with very little effort. I guess there is no perfect RAW converter out there but I really wish the Nikon offerings were a bit faster and more stable. Looking forward to seeing more of your tests Cheers, Stephen
Who is onlineUsers browsing this forum: Majestic-12 [Bot] and 43 guests |
