18-200 VR - how to testModerator: Moderators
18-200 VR - how to testHello,
My 18-200VR just arrived this morning, and I would like to take some test shots with it over the next few days. Does anyone have experience in testing techniques for the VR function? Looking for ideas... Also, ways to test such a wide range zoom? thanks in advance Oz
Take it overseas for a month, travel to lots of different countries and thoroughly enjoy yourself - that's my test - the photos here are my selection, all using 18-200 VR
http://www.pbase.com/justin_aus/europe2006 the test you can do at home for VR is, starting at 200mm and 1/200 and then click shutter speed lower and lower, taking a shot each time - then compare the shots for blur. best done evening of course. D3 | 18-200VR | 50:1.4 | 28:2.8 | 35-70 2.8 | 12-24 f4
Just run it through a normal test procedure.
Go outside, find a nicely lit scene, preferably brick walls? Ah, thats too cliche... but simple patterned scenes are best to test. So an urban scene with a flat wall with windows may be the easiest thing to find around Melbourne (specially those large brick walls). Test all apertures ranging from wide open to the smallest in increments of 1 full stops. Test most common used focal lengths. That is 18, 24, 50, 100, 200. Repeat aperture stops for each focal length. Now the bokeh test, aperture priority, near closest focus of an object (street light or your own studio) and do some tests. Those glue sticks will work good here But I prefer doing it with lights (so the donuts will show up) Make sure your test is done via tripod (for resolution/sharpness), and turn off the VR. So you can use photoshop action to crop the 100% areas afterwards and stick them together to compare. About the VR, just switch it on, turn camera down to shutter priority, start with hand-holdable speed, and move down in 1/3 stops each time. Until you have fully reached a non-holdable speed. That is how it works, the basic. You may also try using VR and pan some subjects at slow speeds (1/100 or 1/50) at 200mm range. Then the possibility goes on... Here is a review I did for a VR lens: AF-S Nikkor 105mm f/2.8G Micro VR If any other questions in doubt, just ask.
THanks Justin, May I ask, what is this ? http://www.pbase.com/justin_aus/image/66496398 regards, Oz
ah, that is a focus test chart I thought I had focus issues- but I think it was really just me on a particularly sticky point of the learning curve...
Ref: this post - http://dslrusers.com/viewtopic.php?t=20935 D3 | 18-200VR | 50:1.4 | 28:2.8 | 35-70 2.8 | 12-24 f4
Who is onlineUsers browsing this forum: No registered users and 35 guests |
